Surface Colormap shows No Data
  • Surface Colormap shows No Data
    If I run a point colormap, I get a good looking result. But, if I run a surface colormap with, as far as I can tell, identical settings, I get no data. Am I missing something? Using PC-DMIS 2019 R2 SP 8. TIA.
    Try changing the max distance and/or try fixing the vectors of the CAD.
    PC-DMIS CAD++ 2o19 R1 SP11
      I've not seen the option for "surface color map", hit F1 and see if it is for a constructed surface and not a point cloud.
        There we go! If anyone else has this issue, I had to go to Edit > Graphic Display Window > CAD Vectors, then select the CAD model and click on Flip Surface Vectors. vpt.se thank you so much for your help! This had me pulling my hair out. 8-)
          Glad to have helped! The dark gray area is what tipped me off, have this happen to me alot as well.
