Operator Comment in a Loop
  • Operator Comment in a Loop
    I have a looped a program to run 2 parts at a time. I've inserted an operator comment towards the end of the loop to tell me how many dimensions measured out of tolerance. It works but it keeps a running tally instead of giving me the results one part at a time.
    ASSIGN/NM=GETPROGRAMINFO("NUMMEAS")
    ASSIGN/OT=GETPROGRAMINFO("NUMOOT")
    COMMENT/OPER,NO,FULL SCREEN=YES,AUTO-CONTINUE=NO,
    "TOTAL MEASURED = "+NM
    "OUT OF TOLERANCE = "+OT
    "OK" TO CONTINUE.
    I'm programming on a Global S 15.30.10 with a HP-S-X1H Scanning Probe, and using 2020 R2.
    At the very end of the loop (but still inside it), put your operator comment.
    Immediately following that (still inside of the loop) create a new assignment for NM and a new assignment for OT to make them both equal 0 (to reset them). When it re-executes the loop, those variables will be now be "fresh"/zeroed out for the second part.
    PC DMIS is very finicky about naming conventions..but..it WILL let you re-use variable names in your program. As long as you're careful and watch what you're doing (and remember to redefine them when need be like I am showing you in this example).
      Pcdmis keeps track of the current running total for NUMMEAS and NUMOOT. You will need to calculate the difference between loops.
      I think this will work but try it to make sure. I tried to give somewhat meaningful names to indicate what I am doing.
      ASSIGN/PRIORLOOPEDMEAS = 0
      ASSIGN/PRIORLOOPEDOOT = 0
      LOOP start area
      near the bottom of the loop calculate your loop information
      ASSIGN/CURRENTLOOPMEAS = NM - PRIORLOOPEDMEAS
      ASSIGN/CURRENTLOOPOOT = OT - PRIORLOOPEDOOT
      ASSIGN/PRIORLOOPEDMEAS = NM
      ASSIGN/PRIORLOOPEDOOT = OT
      CURRENTLOOPMEAS, CURRENTLOOPOOT should contain your current loop information
      End of Loop
        Is this right? It's still doubling the total measured.
        "OK" TO CONTINUE.
        ASSIGN/NM=0
        ASSIGN/OT=0
        LOOP/END
        • DAN_M
          DAN_M commented
          I'm sorry, I accidentally gave you some bad advise. I didn't realize that PC DMIS keeps track of "GETPROGRAMINFO" information. Please see @SABarber's comment #3
        Awesome! It worked! Thank you guys!
