good morning. i have a question for you all. i have 3.5 mr1 ph10 w/ tp20. i need to know if i can change my tip during the middle of my program. i do not have a probe changer. i am using a star probe but will need to change to a 3mmx50mm probe in the middle of my program. is there anything special i need to do, or can it be done. i hate to have to have 2 programs for 1 part. will i need to qualify the tip in program or before. im stummped. thanks in advance for any responses.
stummped
Yes you can do this without a problem if you have a TP20 and two modules. Build each tip on a module. Calibrate each making sure you calibrate the AOBO 1st for each tip. When you get to the point in your program you want to change tip, use move points to move the quill to the from of the table then select the tip you want to change to from the "probes" pulldown window at the top of the pc-dmis screen. Then disable the probe at the jogbox and switch the modules.
When you execute the program it will move to the front and a box will pop up saying, "Please load 3x50" or whatever you have that tip named. HTH
Note: If you have a tp2 or only 1 module, you will have to calibrate the second tip in the middle of the program before going on. The modules for the tp20, tp200, etc are magnetic repeatable connections, but anytime you unscrew any part of a tip build you have lost calibration and must recalibrate.
Originally posted by Kevin Watts View Postwould i have to add a new probe file at the point that i need to change the tip?sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
by D-TrainI need to build a probe tip, 5by70MM. In my probe description pulldown I see some tips labeled 5by50MM and 5by50MM_CF.....what is the CF? I have a 5by75MM_CF...
05-08-2013, 11:15 AM -
by PCFreddieIs it requred to qualify the tip everytime I turn on the machine or change to a new tip? If it is not calibrating the tip then maybe no need to do it...
01-11-2011, 05:27 PM -
Using 3.7 mr3 with a TP20. I'm starting my program out with a 3mm tip and part way thru the program i switch to a 1mm tip by switching modules with both...
05-18-2006, 01:33 PM -
Hi,
I have been running my parts program to inspect parts for years. Last week, when the machine was on, i removed Probe Module from Probe...-
06-12-2012, 12:01 PM -
by csshafferI am currently writing a program and have an issue with tool changing. I need to change my tips 3 times over the course of the program. When I get to...
03-02-2011, 10:36 AM -
