When datums [B] and [C] are both circles through datum [A] plane and [C] is located on the print at 100mm in the X and 20mm in the Y, do you use [C] to set the 20mm offset in Y or do you rotate to [B] and [C] and rotate back the nominal angle (11.31°)?
Beginner alignment question
How about a bestfit alignment?
Start with a regular primary alignment in Z for the plane (zero in Z too).
Make sure you have the Z-workplane active.
Set X and Y-zero in [B].
Enter bestfit alignment section.
Select B and C as your features for the bestfit alignment.
Select 2D - no translation. This will keep the bestfit alignment rotating around B.
Click "Calculate".
Click OK to return to the "regular" alignment dialog.
Click "Create".
If the 20 mm is boxed but the 100 is not, then you should use an offset line between B and C offset with 20 mm and align to that.PC-DMIS CAD++ 2o19 R1 SP11
- 2 likes
I can't show any more than this. In this scenario I would rotate to [C] then rotate back the nominal angle to get to "print" position and not set the offset?
- 1 like
I have an engine block in which crank#5 and crank#1 should be align on its centers of the cranks (cranks#1 is 23"inches away from cranks#5). I'm...
05-01-2006, 03:20 PM -
by Randy Phaving trouble offsetting an iterative alignment using 3.25 mr1. Have done a iterative and want to offset the X-axis .1mm. Is this a version that had...
02-19-2009, 01:40 PM -
by Loon4everHello all
I'm trying to dimension this lovely part and I am running into something I thought might become an issue. This part has 5 Datums...-
01-23-2019, 12:44 PM -
by Slug DawsonI have [-A-] as a Y- plane.
There are 2 circles on this plane; the left one [-B-] is the origin & the right one (cir 3) is [-C-]. B &...-
11-05-2009, 04:29 PM -
Does anybody know about best-fit Alignment and what is difference between Regular Alignment and the best-fit Alignment
Example
09-05-2013, 05:28 AM -
