I have a program with a excel form report command at the end. I'm trying to loop it so I can do 2 parts at once. I've successfully looped it but when it fills my spreadsheet, it won't populate the GD&T dimensions of the 2nd part. I suspect this is because there is not a 2nd CAD model it the program. Am I correct in assuming this and how would I properly place the 2nd CAD model in the program. The parts are 33 inches apart in the X-axis.
2 Part Loop with Excel Form Report
It has nothing to do with a second CAD model, Do you have Print Commands in your program, I assume you do not, because after the first part is ran, it should stop and ask you to save the first part that was run.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
If you do have the Print command in there it should be placed BEFORE- LOOP/END
Does my Excel Form Report command count as a print command? I do have it placed before the end of the loop. For these particular parts I don't want to save the PDF Reports. I only need the data in spreadsheet form. Can I use a Print Command to my running spreadsheet?
https://www.pcdmisforum.com/forum/pc...partial-report POST#3
As I showed in here. Using Excel is fine. With Print Commands its the same thing as "Report Window Print Setup" but it treats it great in looping.Last edited by KIRBSTER269; 10-14-2020, 03:34 PM.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
Code:[COLOR=#2980b9]V1 =LOOP/START,ID=YES,NUMBER=0,START=1,SKIP=, OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=0[/COLOR] [COLOR=#c0392b]PRINT/REPORT,EXEC MODE=END,$ TO_FILE=OFF,AUTO=1,AUTO OPEN REPORT=OFF,$ TO_PRINTER=OFF,COPIES=1,$ TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=,$ REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$ TO_EXCEL_OUTPUT=OFF, PREVIOUS_RUNS=DELETE_INSTANCES<<<<<<<<<<<<<<<<<<<<[/COLOR]DELETE INSTANCES FCF_PROFILE_LEFT_NVS_2 =SURFACE PROFILE : SCN_LEFT FEATCTRLFRAME/SHOWPARAMS=NO,SHOWEXPANDED=NO PRIMARY DIMENSION/PROFILE OF SURFACE,0.1,,, NOTE/FCF_PROFILE_LEFT_NVS_2 FEATURES/SCN_LEFT,, FCF_PROFILE_RIGHT_NVS_2 =SURFACE PROFILE : SCN_RIGHT FEATCTRLFRAME/SHOWPARAMS=NO,SHOWEXPANDED=NO PRIMARY DIMENSION/PROFILE OF SURFACE,0.1,,, NOTE/FCF_PROFILE_RIGHT_NVS_2 FEATURES/SCN_RIGHT,, DATDEF/FEATURE=DATUM_D,D FCFWHOLE_SPHERE =SURFACE PROFILE : SPHERE FEATCTRLFRAME/SHOWPARAMS=NO,SHOWEXPANDED=NO PRIMARY DIMENSION/PROFILE OF SURFACE,0.1,D, ,, NOTE/FCFWHOLE_SPHERE FEATURES/SPHERE,, [COLOR=#c0392b]PRINT/REPORT,EXEC MODE=END,$ TO_FILE=OFF,AUTO=1,AUTO OPEN REPORT=OFF,$ TO_PRINTER=ON COPIES=1,$ <<<<<<<<<<<<<<<<<<<<<<<<<<<<<[/COLOR][COLOR=#000000]printer is on, in this instance you can type OFF[/COLOR] [COLOR=#c0392b]TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=,$ REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMEN SIONS=NO,$ TO_EXCEL_OUTPUT=OFF, PREVIOUS_RUNS=KEEP_INSTANCES<<<<<<<<<<<<<<<<<<<<<<[/COLOR][COLOR=#000000]KEEP INSTANCES[/COLOR] [COLOR=#2980b9]LOOP/END[/COLOR]
right click on the second one and click edit to set it up how you want to export it.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
I can't seem to get the Print Command and the Excel Form Report to work in concert. This is what I tried.
Code:V2 =LOOP/START,ID=YES,NUMBER=2,START=1,SKIP=, OFFSET:XAXIS=33,YAXIS=0,ZAXIS=0,ANGLE=0 PRINT/REPORT,EXEC MODE=END,$ TO_FILE=OFF,AUTO=1,AUTO OPEN=OFF,$ TO_PRINTER=OFF,COPIES=1,$ TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=,$ REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMEN SIONS=NO,$ TO_EXCEL=OFF,$ PREVIOUS_RUNS=DELETE_INSTANCES - - -FEATURES AND DIMENSIONS - - EXCEL_FORM1 =EXCELFORMREPORT/TEMPLATE=MEDIUM_CHASSIS_TEMPLATE, TYPE=XLSX RESULT FOLDER/C:\Users\Public\Documents\Hexagon\PC-DMIS\2019 R2\ExcelFormReport\Results ASSIGN/EFR=GETPROGRAMINFO("EXCEL_FORM1") PRINT/REPORT,EXEC MODE=END,$ TO_FILE=OFF,AUTO=1,AUTO OPEN=OFF,$ TO_PRINTER=OFF,COPIES=1,$ TO_DMIS_REPORT=OFF,FILE_OPTION=INDEX,FILENAME=,$ REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMEN SIONS=NO,$ TO_EXCEL=ON,AUTO=3,FILENAME=EFR,AUTO OPEN=OFF,$ PREVIOUS_RUNS=KEEP_INSTANCES LOOP/END
I'm programming on a Global S 15.30.10 with a HP-S-X1H Scanning Probe, and using 2020 R2.
It still ends up saving like this, the first part saves fine but the 2nd part is missing the measured GD&T.
spreadsheet.pngI'm programming on a Global S 15.30.10 with a HP-S-X1H Scanning Probe, and using 2020 R2.
ok your not even using the print command, I was under the impression that's what you were using. This is actually what is dumping your info. and populating your form. So you can get rid of the Print Commands.
Code:EXCEL_FORM1 =EXCELFORMREPORT/TEMPLATE=MEDIUM_CHASSIS_TEMPLATE, TYPE=XLSX RESULT FOLDER /C:\Users\Public\Documents\Hexagon\PC-DMIS\2019 R2 \ExcelFormReport\Results ASSIGN/EFR=GETPROGRAMINFO("EXCEL_FORM1")
Is the info actually missing or is the information doubled in each slot in Excel? Can you expand the slots and see if the second reading is hidden?Last edited by KIRBSTER269; 10-15-2020, 08:08 AM.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
Code:V1 =LOOP/START,ID=[COLOR=#c0392b]NO[/COLOR],NUMBER=0,START=1,SKIP=, OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=0 ********************************** PROGRAM ********************************** EXCEL_FORM1=EXCELFORMREPORT/TEMPLATE=B69678(MEDIUM)_TEMPLATE, TYPE=XLSX RESULT FOLDER/C:\Users\Public\Documents\Hexagon\PC-DMIS\2019 R1\ExcelFormReport\Results LOOP/END
Last edited by KIRBSTER269; 10-15-2020, 03:27 PM.(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
by GermanMexI want to use the excel report command in pcdmis , but when using the loop it does not report the elements, it only reports the last execution of the...
11-25-2020, 05:55 PM -
by MihaelRHi guys,
I have to measure one product 10 times for a gage R&R. So instead clicking 10 times for a new measurement, I started a loop...-
02-15-2017, 05:28 PM -
by spsayeskiWhen running a loop to run multiple parts, how can you
1. Set up tracefields for serial number and fixture numbers for each part
2. have...-
11-03-2013, 06:25 AM -
by Charlie8So I have a program that inspects the hubs of a blisk. I use a loop (LOOP/START, LOOP/END type) to do each cavity, creating 90 vector points per hub,...
05-24-2016, 10:26 AM -
by lamboI built a loop to check I.D. of 10 bearings and I saved it but when I retreived the report shows only the last result (ID size of the 10th bearing only)....
05-19-2008, 10:06 AM -
