2020R1 - Location for Radius
  • 2020R1 - Location for Radius
    Hello,
    When I measure a radius with an autocircle then report the radius it only show the theoretical as the measured value. I am reporting from Location > R. If I use the Size Dimension icon It reports the measured diameter. Is there a setting that could off, or a bug with 2020?
    Thanks,
    I had my auto circle set to fixed rad, but when I changed to max inscribed or least squares it started reporting.
      Yes because:
      Fixed Radius - This calculation type creates a circle of a given diameter, positioned so that the maximal radial distance from the data points to the circle is minimized. It is similar to the Max/Min math used in the MIN_SEP calculation except that, since the diameter is known in advance, the radius cannot vary. Only the circle's position is allowed to vary.
      © F1 Help
