Feature messurment offset
  • Feature messurment offset
    Hello,
    I heave a part witch I measure tactile and with laser on a Global CMM on the same fixture.
    With the laser I get constant deviation to the tactile measurment. I would like to offset some laser mesured features for the difference, any ideas how? The nominals must stay the same, only the measured xyz need to be offset.
    The laser masurment needs to be fast so i don´t heave time to scan slower or 2 time to get better results, also the part does not help because the sheet matal parts are reflecting.
    Thanks, Bojan
    Maybe it's the calibration of the laser which is bad ?
    How do you perform it ?
    How do you link tactile and laser calibration spheres ?
      With rfference tip I measure bouth spheres before I start auto calibration rutine. I also heave a rotine to chek tips one to another and the laser and it is within tolerance.
      GT_2_U_RE =ELEM//KREIS/STANDARD,KARTESISCH
      NENN/<-234.5,279.5,-185.6>,<0,0,-1>,16
      MESS/<-234.42,279.7,-185.98>,<0.0199961,0.0271286,-0.9994319>,16.77
      ZIEL/<-234.5,279.5,-185.6>,<0,0,-1>
      PROTOKOLLVEK=<0,0,-1>
      ELEMENTPARAMETER EINBLENDEN=NEIN
      LASERPARAMETER_ANZEIGEN=JA
      GT_2_U_RE_P=ELEMENT/PUNKT,KARTESISCH,NEIN
      NENN/<-234.75,279,-185.6>,<0,0,-1>
      MESS/<-234.67,279.2,-185.98>,<0.0199961,0.0271286,-0.9994319>
      KONST/PUNKT,VERSATZ,GT_2_U_RE,-0.25,-0.5,0
      Edit:
      This changes my nominals, not what I was aming for...
        Come up with a solution, it is far from simple....
        Measured feature:
        Offset feature:
        TEST =BENUTZERDEFINIERT/KREIS,ABHÄNGIG,KARTESISCH,AUSSEN,$
        NENNW/XYZ,<GT_2_U_RE.TEX,GT_2_U_RE.TEY,GT_2_U_RE.TEZ>,$
        MESS/XYZ,<GT_2_U_RE.X+0.25,GT_2_U_RE.Y+0.5,GT_2_U_RE.Z> ,$
        NENNW/IJK,<0,0,-1>,$
        MESS/IJK,<0,0,-1>,$
        DURCHM/0,16
        yes my PC-Dmis is in German...
        • Cobe73
          3 Datum Points
          by Cobe73
          'm Having a problem. I have a Part with 3 datum points for the Datum A. 2 of the points are 4mm above the one point. There is a perpendicular callout...
          07-15-2015, 11:00 AM
        • JThomas
          Assignment Question
          by JThomas
          I never use assignments simply because I do not know how, I am supposed to get more training in January,...That said, I work with heavy steel parts, formed...
          12-13-2011, 02:22 PM
        • JEFMAN
          Cone problem
          by JEFMAN
          I often have to measure short cones / large diameter.
          I noticed than measuring or constructing a cone with a length of 1 mm gives strange results,...
          09-12-2019, 05:28 AM
        • DHoye
          Calibration
          by DHoye
          After calibrating probe...best i could get on standard deviation was .0007....
          i am consistently off on my X by .0009mm on a 50mm master ring...am...
          03-24-2008, 01:51 AM
        • Jim Poehler
          Help me please...need variable expression
          by Jim Poehler
          I will be the first to admit that I am not up to using expressions. Have this situation where I need to measure a depth of a ring groove and subtract...
          10-16-2018, 01:43 PM
