To excel
  • To excel
    Using from the file menu:
    File>Printing>Report Window print Set-Up> EXCEL
    I have it set to report as a CSV. When I run offline and the 1st run online the Excel report saved in this format:
    F10_X UNITS MM
    F10_X Dimension Location (F1) X 1.53 1.588594 0.13 0.13 0.058594 0
    F11_M UNITS MM
    F11_M Dimension 2d Distance (DATUM_C,SCN24.HIT[1]) M 250 1368.14 250 0 1118.14 868.1403
    F12_D UNITS MM
    F12_D Dimension Location (CYL46) D 343.36 343.36 0.1 0.1 0 0
    F13_TP UNITS MM
    F13_TP Dimension Position (CYL46) X 0 7.171144 7.171144
    F13_TP Dimension Position (CYL46) Y 0 4.65606 4.65606
    F13_TP Dimension Position (CYL46) DF 343.36 343.36 0.1 0.1 0 0 0
    F13_TP Dimension Position (CYL46) TP 0 17.1002 0.2 0 17.1002 16.9002 32.99474
    But after the 1st run the rest reported like this:
    F10_X UNITS MM
    DIMENSION DESCRIPTION FEATURE AXIS SEGMENT NOMINAL MEAS +TOL -TOL BONUS DEV OUTTOL DEVANG DATUM SHIFT EFFECT UNUSED ZONE SHIFT X SHIFT Y SHIFT Z ROTATION X ROTATION Y ROTATION Z
    F10_X Dimension Location (F1) X 1.53 1.575849 0.13 0.13 0.045849 0
    F11_M UNITS MM
    F11_M Dimension 2d Distance (DATUM_C,SCN24.HIT[1]) M 250 305.9504 250 0 55.95042 0
    F12_D UNITS MM
    F12_D Dimension Location (CYL46) D 343.36 343.3185 0.1 0.1 -0.04148 0
    F13_TP UNITS MM
    F13_TP Dimension Position (CYL46) X 0 -0.00161 -0.00161
    F13_TP Dimension Position (CYL46) Y 0 0.008567 0.008567
    F13_TP Dimension Position (CYL46) DF 343.36 343.3185 0.1 0.1 0 -0.04148 0
    F13_TP Dimension Position (CYL46) TP 0 0.017433 0.2 0 0.017433 0 100.6193
    F14_D UNITS MM
    F14_D Dimension Location (DATUM_A) D 300.9 300.9068 0.1 0.1 0.006812 0
    Any logical reason as to why?
    I need the Excel formatting to look like the top format
    Jesse Krook
    Luckily the programs ran were saved and I re-execute this offline and saved as the 1st format. I'm totally cornfused now???? Exact same program 2 different out-puts
    Jesse Krook
      PRINT/REPORT,EXEC MODE=END,$
      TO_FILE=ON,PROMPT,AUTO OPEN=ON,$
      TO_PRINTER=ON,COPIES=1,$
      REPORT_THEORETICALS=IMPORT_SETTING,REPORT_FEATURE_ WITH_DIMENSIONS=NO,$
      TO_EXCEL=OFF,$
      PREVIOUS_RUNS=KEEP_INSTANCES
      ASSIGN/V7=0
      WHILE/V7<>50
      ASSIGN/V7=V7+1
      END_WHILE/
      TO_FILE=OFF,AUTO=1,AUTO OPEN=OFF,$
      TO_PRINTER=OFF,COPIES=1,$
      TO_EXCEL=ON,AUTO=10,FILENAME=\\prod02\Main_QualityData\CUSTNAME\CUSTPARTNO-000\CMMData\Final\CUSTPARTNO-000_Final.CSV,AUTO OPEN=OFF,$
      Jesse Krook
        Make sure your Field information is set up properly in your print commands. I looks like it is adding the labels on each line.
          What you have picture is exactly how I have it set
          Jesse Krook
