2019 r2 sp8
  • 2019 r2 sp8
    Here :
    http://software.hexagonmi.com/public...19_R2/SP8/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R2/SP8/x64/
    Release Notes - 2019 R2 SP8
    • PCD-146826 - Fixed an issue where the Gaussian filter didn't work when you created a measurement in the inch mode.
    • PCD-163923 - Fixed an issue where PC-DMIS didn't show correct leader line's style when you applied it from the Label Layout Wizard dialog box.
    • PCD-164339 - Fixed an issue where both perpendicularity and parallelism showed an incorrect color representation of the size deviation graphic colors.
    • PCD-177908 - Fixed an issue where PC-DMIS showed incorrect results when you calculated ESF features with and without actual thickness.
    • PCD-178948 - Fixed an issue where PC-DMIS didn't apply the No data color that you selected in the Color Scale Editor dialog box for areas on the part where no data was found.
    • PCD-186451 - Fixed an issue where PC-DMIS prevented the clearing of a feature list when you selected a new geometric tolerance from the Xact Measure dialog box.
    • PCD-186811 - Fixed an issue where the Use datums check box in the legacy Position dialog box was turned on for all dimensions when you selected the Use datums check box for only a single dimension.
    • PCD-188047 - Fixed an issue where the probe tips were duplicated in the probe file.
    • PCD-189807 - Fixed an issue where PC-DMIS was not able to export ESF (VWMP) features to a DMIS file.
    • PCD-191049 - Fixed an issue where the variables with a fixed text were imported incorrectly when you imported a DMIS file.
    • PCD-191254 - Fixed a software crash that occurred when you opened the Constructed Plane dialog box and selected Primary Datum from the list.
    • PCD-192158 - Fixed an issue where Q-DAS Configurator doesn't output the correct value for the legacy Profile Form and Location.
    • PCD-192526 - Fixed an issue where the Shift + right mouse button in the Graphic Display window corrupted the mouse controls.
    • PCD-194153 - Fixed an issue where the pointcloud cross-section annotations were not updated automatically when you changed the associated profile line tolerances.
    • PCD-194910 - Fixed a software crash that occurred when you scrolled in the Edit window of the Summary (Preview) mode.
    • PCD-195192 - Fixed an issue where PC-DMIS showed an incorrect collision message when you calibrated a list of tips twice and didn't close the Probe Utilities dialog box.
    • PCD-195513 - Fixed an application error that occurred when you pasted an ESF feature that doesn't carry a VW standard name.
    • PCD-195737 - Fixed an issue where an improper move in an incorrect direction occurred at the start of a Defined Scan with a Zeiss VAST XT probe when a measurement routine used Imperial units.
    • PCD-195874 - Fixed an issue where an event was missing in the EventModule.xml file in the onClosingApplication command.
    • PCD-195962 - Fixed a software crash that occurred when you worked on a laser scan in Dual Arm mode.
    • PCD-197422 - Fixed an issue where PC-DMIS converted the nominal incorrectly when you edited the Distance command and changed the units from inch to mm.
    • PCD-197763 - Fixed an issue where the Paste With Pattern feature failed when all the axis values were not defined in the Move/Point command.
    • PCD-198324 - Fixed an issue where PC-DMIS showed an error message when you created a QdasData.xml file with a legacy true position dimension with axes in polar coordinate.
    • PCD-198541 - Fixed an issue where PC-DMIS was not able to parse the OCR file when you used the GD&T Selection Mode (from file) option from the Graphic Modes toolbar.
    • PCD-199068 - Fixed a software crash that occurred when you created a plane through the feature widget and attached a plane circle scan strategy to it.
    • PCD-199946 - Updated a DLL to help fix a software crash that occurred when you closed a measurement routine.
    • PCD-200640 - Fixed the HP-TM components issue which included updating the nomenclature from HP-TM2 to HP-TMe, and ensured the compatibility with the Samara rack (HP-MP).
    • PCD-201302 - Fixed an issue where PC-DMIS Home page couldn't display the News feed on the upper-right corner of the page.
