Cad=part
  • Cad=part
    Hello all while writing a program with a model I did my manual alignment but the CAD=PART button did not come up. Any one else run into this or could it be my features I am using to align. B&S Global Image 3.7MR2
    STARTUP =ALIGNMENT/START,RECALL:, LIST= YES
    ALIGNMENT/END
    MODE/MANUAL
    LOADPROBE/1BY20 MM
    COMMENT/OPER,NO,Place part in left front corner of large mag
    ,block. Flush with mag block and lobes at
    ,12 and 6 O'clock.
    C1 =COMMENT/YESNO,NO,Would you like to do a manual alignment?
    ,If Yes the take 3 hits on the large mag
    ,block for the plane.
    ,Take 3 hits on the large radius of the lobes
    ,at 6 and 12 O'clock left and right side. It is
    ,important to do the 6 O'clock first then the
    ,12. This is for the line.
    ,Take 6 hits on the 38.62 ID for the origin
    IF/C1.INPUT=="YES"
    PLN1 =FEAT/PLANE,RECT,TRIANGLE
    THEO/349.582,228.726,-516.419,-0.0002969,-0.0000148,1
    ACTL/349.582,228.726,-516.419,-0.0002969,-0.0000148,1
    MEAS/PLANE,3
    HIT/BASIC,NORMAL,326.552,50.491,-516.429,-0.0002969,-0.0000148,1,326.552,50.491,-516.429,USE THEO = YES
    HIT/BASIC,NORMAL,414.971,242.994,-516.4,-0.0002969,-0.0000148,1,414.971,242.994,-516.4,USE THEO = YES
    HIT/BASIC,NORMAL,307.222,392.693,-516.429,-0.0002969,-0.0000148,1,307.222,392.693,-516.429,USE THEO = YES
    ENDMEAS/
    6LEFTRAD =FEAT/CIRCLE,RECT,IN,LEAST_SQR
    THEO/319.493,27.15,-514.835,0,0,1,5.411
    ACTL/319.493,27.15,-514.835,0,0,1,5.411
    MEAS/CIRCLE,3,WORKPLANE
    HIT/BASIC,NORMAL,319.629,24.448,-514.835,-0.0501196,0.9987432,0,319.629,24.448,-514.835,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,320.971,24.883,-514.835,-0.5459608,0.8378107,0,320.971,24.883,-514.835,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,322.187,26.892,-514.835,-0.9954249,0.095547,0,322.187,26.892,-514.835,USE THEO = YES
    ENDMEAS/
    6RIGHTRAD =FEAT/CIRCLE,RECT,IN,LEAST_SQR
    THEO/331.406,27.198,-515.52,0,0,1,5.282
    ACTL/331.406,27.198,-515.52,0,0,1,5.282
    HIT/BASIC,NORMAL,330.1,24.902,-515.519,0.4946938,0.8690674,0,330.1,24.902,-515.519,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,329.093,25.922,-515.52,0.875697,0.482861,0,329.093,25.922,-515.52,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,328.768,27.082,-515.519,0.9990429,0.0437422,0,328.768,27.082,-515.519,USE THEO = YES
    ENDMEAS/
    PNT1 =FEAT/POINT,RECT
    THEO/325.45,27.174,-515.177,0,0,1
    ACTL/325.45,27.174,-515.177,0,0,1
    CONSTR/POINT,MID,6LEFTRAD,6RIGHTRAD
    12LEFTRAD =FEAT/CIRCLE,RECT,IN,LEAST_SQR
    THEO/319.236,71.79,-514.451,0,0,1,5.37
    ACTL/319.236,71.79,-514.451,0,0,1,5.37
    HIT/BASIC,NORMAL,319.263,74.474,-514.452,-0.010148,-0.9999485,0,319.263,74.474,-514.452,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,319.893,74.393,-514.451,-0.2445901,-0.9696266,0,319.893,74.393,-514.451,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,321.82,72.517,-514.451,-0.9626662,-0.2706913,0,321.82,72.517,-514.451,USE THEO = YES
    ENDMEAS/
    12RIGHTRAD =FEAT/CIRCLE,RECT,IN,LEAST_SQR
    THEO/331.154,71.88,-514.924,0,0,1,5.331
    ACTL/331.154,71.88,-514.924,0,0,1,5.331
    HIT/BASIC,NORMAL,330.235,74.382,-514.924,0.3449126,-0.9386348,0,330.235,74.382,-514.924,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,328.974,73.414,-514.924,0.817833,-0.5754556,0,328.974,73.414,-514.924,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,328.498,71.652,-514.924,0.9963429,0.0854446,0,328.498,71.652,-514.924,USE THEO = YES
    ENDMEAS/
    PNT2 =FEAT/POINT,RECT
    THEO/325.195,71.835,-514.687,0,0,1
    ACTL/325.195,71.835,-514.687,0,0,1
    CONSTR/POINT,MID,12LEFTRAD,12RIGHTRAD
    LIN1 =FEAT/LINE,RECT,UNBND
    THEO/325.45,27.174,-515.177,-0.0057068,0.9999837,0
    ACTL/325.45,27.174,-515.177,-0.0057068,0.9999837,0
    CONSTR/LINE,BF,2D,PNT1,PNT2,,
    OUTLIER_REMOVAL/OFF,3
    FILTER/OFF,WAVELENGTH=0
    ID =FEAT/CIRCLE,RECT,IN,LEAST_SQR
    THEO/325.343,49.502,-514.737,0,0,1,38.617
    ACTL/325.343,49.502,-514.737,0,0,1,38.617
    MEAS/CIRCLE,6,WORKPLANE
    HIT/BASIC,NORMAL,325.025,68.805,-514.737,0.0164764,-0.9998643,0,325.025,68.805,-514.737,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,342.047,59.198,-514.736,-0.8648586,-0.5020155,0,342.047,59.198,-514.736,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,342.279,40.239,-514.737,-0.8773428,0.4798642,0,342.279,40.239,-514.737,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,325.3,30.192,-514.737,0.0022093,0.9999976,0,325.3,30.192,-514.737,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,308.71,39.694,-514.737,0.8613805,0.5079602,0,308.71,39.694,-514.737,USE THEO = YES
    MOVE/CIRCULAR
    HIT/BASIC,NORMAL,308.974,59.744,-514.737,0.8477431,-0.530407,0,308.974,59.744,-514.737,USE THEO = YES
    ENDMEAS/
    A0 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
    ALIGNMENT/LEVEL,ZPLUS,PLN1
    ALIGNMENT/ROTATE,YPLUS,TO,LIN1,ABOUT,ZPLUS
    ALIGNMENT/TRANS,XAXIS,ID
    ALIGNMENT/TRANS,YAXIS,ID
    ALIGNMENT/END
    END_IF/
    Since I gave up hope I feel much better !!!
    IF you are inserting the alignment in the program, WITH features after the insertion point, the CAD=PART button is NOT available. After you do the alignment and close the alignment window, you can do CAD=PART by going to:
    OPERATION
    GRAPHICS DISPLAY WINDOW
    it will be in the list.
      Why thanks Matt I was starting rip out the few hairs I have left on my head :-)
      • Ken379128
        Iterative alignments
        by Ken379128
        I was trying out iterative alignments and I did cad = part and the measurements and cad model did not snap together. Below is th code
        Brown and...
        10-30-2007, 07:51 AM
      • KENNETH BAKER
        help
        by KENNETH BAKER
        I,m trying to write my first program, and not having a easy time of it. I was in Chicago last week for a PC-DMIS cad course. I thought I had a grasp of...
        09-19-2007, 04:32 PM
      • Ken379128
        off set in alignment
        by Ken379128
        I am trying to move my trihedron with offsets. I have the orignal alignment put in when I try to off set the circle in the x and y I can only move in...
        07-03-2007, 03:08 PM
      • emurray
        Please take a look
        by emurray
        I am running a pre-existing program for one of our parts. The problem I am having (this time) is after I am prompted to take my manual measurments,...
        08-14-2007, 01:32 PM
      • dwade
        Dilemma with datums
        by dwade
        What I have run into while looking into correlation issues with a customer is datum feature measurement. The parts were programmed with CAD (and using...
        06-04-2014, 03:13 PM
