here :
http://software.hexagonmi.com/public...20_R1/SP6/x64/
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R1/SP6/x64/
Release Notes - 2020 R1 SP6
• PCD-201302 - Fixed an issue where PC-DMIS Home page couldn't display the News feed on the upper-right corner of the page.
• PCD-200694 - Fixed an automation issue where PC-DMIS was not able to activate the Use COP check box in the Linear Open Scan dialog box.
• PCD-200643 - Fixed an issue where PC-DMIS wouldn't set the Stripe Distance and Exposure values in the Linear Open Scan dialog box and Edit window for the Eagle Eye sensor.
• PCD-199946 - Updated a DLL to help fix a software crash that occurred when you closed a measurement routine.
• PCD-199556 - Fixed an issue where PC-DMIS required two clicks to select a feature when you selected a surface with a different orientation.
• PCD-199068 - Fixed a software crash that occurred when you created a plane through the feature widget and attached a plane circle scan strategy to it.
• PCD-198515 - Fixed an issue where PC-DMIS didn't import specific geometry STEP models.
• PCD-198346 - Fixed a software crash that occurred when you collapsed or positioned your mouse pointer over any group item.
• PCD-198282 - Fixed an issue where PC-DMIS Settings Editor wouldn't setup the CMM2 registry entry keys correctly when you installed PC-DMIS on a new computer.
• PCD-197714 - Fixed an issue where the Auto Intensity for CWS didn't work properly when you queried the calibration table from the PRECITEC controller.
• PCD-197509 - Fixed an issue where the surface colormap annotations didn't appear at the correct location when a measurement routine was opened and saved in one version of PC-DMIS, and then you tried to open and save it in another version.
• PCD-197422 - Fixed an issue where PC-DMIS converted the nominal incorrectly when you edited the Distance command and changed the units from inch to mm.
• PCD-196204 - Fixed an issue where the ESF (VWMP) features selection on a CAD data didn't work when there was a pointcloud data over the CAD model.
• PCD-196048 - Fixed an I++ issue where there was no information for a tool change on Arm2 when you pressed Ctrl + M to insert a move point.
• PCD-195155 - Restored the DebugFlush registry entry in the PC-DMIS Settings Editor.
• PCD-194153 - Fixed an issue where the pointcloud cross-section annotations were not updated automatically when you changed the associated profile line tolerances.
• PCD-192526 - Fixed an issue where the Shift + right mouse button in the Graphic Display window corrupted the mouse controls.
• PCD-192158 - Fixed an issue where Q-DAS Configurator doesn't output the correct value for the legacy Profile Form and Location.
• PCD-191254 - Fixed a software crash that occurred when you opened the Constructed Plane dialog box and selected Primary Datum from the list.
• PCD-186811 - Fixed an issue where the Use datums check box in the legacy Position dialog box was turned on for all dimensions when you selected the Use datums check box for only a single dimension.
• PCD-186451 - Fixed an issue where PC-DMIS prevented the clearing of a feature list when you selected a new geometric tolerance from the Xact Measure dialog box.
• PCD-183067 - Fixed an issue where a measurement routine took a long time to save and close files when a measurement routine contained large pointclouds.
• PCD-178948 - Fixed an issue where PC-DMIS didn't apply the No data color that you selected in the Color Scale Editor dialog box for areas on the part where no data was found.
• PCD-178003 - Fixed an issue where the Probe and Probe Trigger Options tab were not visible in the Parameter Settings dialog box when you edited the AutoTrigger command.
• PCD-164339 - Fixed an issue where both perpendicularity and parallelism showed an incorrect color representation of the size deviation graphic colors.
