Best way you have found to pull data from PCDMIS
  • Best way you have found to pull data from PCDMIS
    Aside from using SPC software like QDAS. What are some ways you use to pull data from PCDMIS?
    Currently I use assignments & write them to a CSV file. Then I created a power query in excel that pulls data from the CSV automatically so the CSV never gets disturbed. Anyone has access to the saved power query reports. The power query has Formatting to show red if the feature is out of TOL "including calculating bonus for TP features".
    This allows us to not have 1000s of saved PDFs or printed reports and the data for that part is all in one place. Where we can use the data to determine capability or go back in time to see if we have had issues.
    use the excel functions and save as csv. same I have a widget that IT created for me that reads the csv and can create a report window and graphs if needed. Or I use other means but with gloves and carefully in case I run into bugs....
      I also use Power Query in Excel. I don't pull values and write to a CSV though, I just use the Excel Output function on the Report Window Print Setup within PC-DMIS and save each report as its own Excel file. I have a master Excel document that searches a specified directory for reports, and pulls data from the Excel reports based on dimension names only, cell location has no effect on it. So if I add/ remove dimensions to the report, or rearrange the order of the dimensions, the Excel still grabs the correct data. I have it set up to display graphs to track dimensions and to display XY plots for true positions. The only downside to it is if there is a whole bunch of data, it will take Excel a few minutes to process it all...
      • vpt.se
        vpt.se commented
        X/Y plots for TP sounds sexy, care to share?
      • Matthew D. Hoedeman
        Matthew D. Hoedeman commented
        Per the X/Y plot, there are some interesting things on the webz about making a round target plot for this sort of thing, but it gets complicated. HOWEVER a simple XY SCATTER chart in Excel will do it, but you are limited to TWO axis in the plot, so no tolerance limits, just a symbol (your choice) where the X&Y are. I set mine up to use deviation not actual so that the symbols are around the zero axis of the chart. This XY chart sits next to a standard run chart.
      • Mike Ruff
        Mike Ruff commented
        I've been meaning to share it on here for a while now. I created it for an ITAR part and my template is still loosely based on this part. I need to remove some dimensions and clean up a few other things and I will upload it on here
      Mike Ruff That sounds nice! Could u share an example?
        VPT.SE, here is what mine looks like:
          I usually use XL or .csv files even though we have an old seat of DataPage (I used to use it extensively at previous employer). For me it just as easy to pull data out of an XL sheet or csv as macros are pretty easy to create.
          Contura Calypso 5.4
            vpt.se Here is my take on X/Y Plots
            From my CSV data i can copy the data over to my excel form "data Tab" move to the "analysis Tab" Clicking Calculate this will Calculate Cp/Cpk and other stats. Then in the top right i have other buttons for auto graph creation. The Attached graph for TP shows upper control limit based off the worst axis along with the tolerance and Average bonus tolerance we are getting and also can auto create histogram or run chart. This is all done with a few button clicks using VBA
            If anyone is interested here is where my TP chart is based off of. https://www.infinityqs.com/support/p...-true-position
            I don't personally use there spc software, but I liked how they handled TP capability
            • vpt.se
              vpt.se commented
              Impressive! The TPchart is really nice!
            ​This is what mine looks like. You can see the different graphs and also a sample of the data the power query is pulling from the individual CMM reports.
            normal graph.jpghttps://www.pcdmisforum.com/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==tp graph.jpghttps://www.pcdmisforum.com/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==power query.jpghttps://www.pcdmisforum.com/image/gif;base64,R0lGODlhAQABAPABAP///wAAACH5BAEKAAAALAAAAAABAAEAAAICRAEAOw==
              Thank you all for demonstrating! My "wish" is to create something similar directly available within PC-DMIS (not for historical/statistical purposes) for reporting, like nominal hole VS measured hole (with it's size scaled so you easily could see if it fits) position. I have been wanting to enhance the TP reporting in PC-DMIS for quite some while now...
              PC-DMIS CAD++ 2o19 R1 SP11
                Something I posted on the dark side with the C M M G U Y S
                http://*******.com/forum/showthread.php?t=39269
                Won't do datum shift. Haven't figured out how to calculate it. I think the "bomb problem" is the right approach but not sure how to implement it. @Jeffman ?
                  I created a cool tool called RepDmis
                  Basically a report database so you can view any report by selecting a Part Number then instance (date/Serial Number)
                  Also got a History view so it will chart and dimension in a similar fashion.
                  https://www.dropbox.com/s/2frp2xyldattxnj/rd1.jpg?dl=0
                  https://www.dropbox.com/s/n3g4tvf4karlqy7/rd2.jpg?dl=0
                  • Darius11
                    Darius11 commented
                    Well done, looks nice!
                  • vpt.se
                    vpt.se commented
                    Your stuff is awesome too NinjaBadger
