legacy position report with MMC bonus not showing
  • legacy position report with MMC bonus not showing
    on my legacy position report I don't see the feature MMC bonus, how can I turn this back on?
    In the report window, right click on the label and select edit object. You will see a series of check boxes to turn each field on or off.
      when I check the box and refresh the page it's still not there, when I go back to it is unchecked again.
      also is there away to globally add this to all reports?
        What version are you using?
        If I remember correctly in 2019 R1 there was a bug regarding this.
        I think it was fixed only in 2019 R2 and not in R1
          2019 r1
            You could try re-instating the backup reporting labels & templates - assuming you don't have any specially modified ones of your own.
            Go to "C:\Program Files\Hexagon\PC-Dmis version\DefaultReportingTemplateBackup" or if it's pre 2016 "C:\Program Files\WAI\PC-Dmis version\DefaultReportingTemplateBackup" and copy the contents then past them into your reporting folder (usually found in the public documents area - "C:\Users\Public\Documents\Hexagon\PC-DMIS\version\Reporting")
              This only occurs when you don't run the whole program. instead of clicking on the refresh button. push the button I highlighted. in the second picture. always has done this.
                nope still not working
                  I don't think its possible to get it working in 2019 R1.
                  With me it worked with all earlier versions and it worked with again with 2019 R2.
                  2019 R1 didn't work no matter what service pack I tried. Maybe one of the newer service packs fixed it witch I didn't try.
                  • vpt.se
                    vpt.se commented
                    Same here, 2019 R1 SP10 - works fine.
                  • Aaron Baldauf
                    Aaron Baldauf commented
                    @vpt.se
                    I don't use this verion anymore so I can't test it, but could it be because of the set language?
                    I use PC-DMIS in german.
                    I remember trying everything but couldn't get Bonus on legacy dimension to show no matter what.
                    But I don't remember what was the last SP I tried.
                    Once I changed to 2019 R2 it worked again.
                  • vpt.se
                    vpt.se commented
                    Well, I am running swedish and it works... It *shouldn't* have an impact, but you never know.
                  To Follow up on what neil.challinor said right click on the label choose edit, and make sure Bonus is checked. If this fails reboot your computer probably a hiccup.
                    it only works with xact measure but not in legacy
                      you probably have to change to TEXT ONLY since those colorful picture boxes were made for Xact and not Legacy. I have no problems getting the bonus for legacy with text only.
                        Yeah it don't work, just another reason not to use Legacy unless your manufacturing a swing set.
                        • A-machine-insp
                          A-machine-insp commented
                          KIRBSTER269 I always use Xact (GeoTol in 2020 R2). My boss wants me to do a reference dimension in legacy for all the Xact I use... but I don't. One of my glorious coworkers has and will delete my Xact and keep the legacy which is why I don't do the legacy reference dimensions anymore.
                        MikeF
                        It look's like the bug didn't get fixed. If you can't update to 2019 R2 you could try to at least put the bonus value in to a comment under the feature.
                        Assuming the feature is called "POS_1" it should look something like this:
                        ASSIGN/V_BONUS=POS_1.TP.BTOL
                        COMMENT/REPT,
                        "Bonus tolerance " +V_BONUS
                        I'm not at a machine so it could differ a bit.
                          Originally posted by Aaron Baldauf View Post
                          MikeF
                          COMMENT/REPT,
                          COMMENT/REPT,
                          "Bonus Tolerance= "+V_BONUS+"
                          Just to space it out a little.
