Whats happneing to my PC-DMIS...is it corrupt?
  • Whats happneing to my PC-DMIS...is it corrupt?
    I have been using this same PC-DMIS 2014 version for approximately 6 years, daily. Never had this problem before, and now it happens every time on every feature. I restarted the computer, restarted the CMM. No sure what else to do. This is a brand new program, nothing else open but PC-DMIS. Happens on every CAD model I have tried.
    When I try to insert an autofeature, the first attempt always has these path lines/movements to the middle of nowhere. I hit close and open autofeature again and its fine. If I insert the autofeature with the lines, the CMM will actually follow the corrupt path lines. This happens on every autofeature I try to input. Insert auto circle > click circle on CAD > get crazy pathlines for no reason > close auto circle > insert auto circle > click circle on CAD > fine. Should I just reinstall PC-DMIS?? Any other tips to try?
    Try creating a completely new probe file and see if that has the same issue. I suspect it may be something o do with the measured data in probe file that you are using.
      I see this also in 2017.
        Disable void detection (the green dotted square icon with a hole in it) and see if that helps.
        PC-DMIS CAD++ 2o19 R1 SP10
        • VinniUSMC
          VinniUSMC commented
          I see it on auto-features in MODE\MANUAL, and void detection isn't an option for manual mode.
        • vpt.se
          vpt.se commented
          The picture posted by the OP shows void detection enabled and in manual mode, so that's why I suggested it.
        I have seen this happen on both 2016.0 and 2019R1. Never been an issue in actual execution however. I always thought it was just a bug.
        • VinniUSMC
          VinniUSMC commented
          Same for me.
        +1
          Run the "TEST" option it will get rid of that.
          Jesse Krook
            This happens to me occasionally in 2019 R2. Usually just closing out of PC-DMIS and opening back up fixes. Obviously this didn't work for you but its an issue across a lot of versions.
              Also have this kind of bug in 2018 R2, path lines sometimes don't update, i have to close and open again the feature.
              last week i even had issues with the pitch, i entered some pitch value into an auto-circle, but every time i change an other value in that window the path lines resume without pitch. I had to close and enter the pitch in last to get it worked !
                Doublecheck the sample points section so that you don't have a feature selected "as sample points".
                Judging from the replies in here though, it looks like it is a bug.
                • YGOLORTEM
                  YGOLORTEM commented
                  It's definitely a bug. Happens to me sometimes but not all the time. Sometimes turning sample points on and off helps
                • YGOLORTEM
                  YGOLORTEM commented
                pcdmis2020 happens all the time.
                my fix is t open up a file, then open the file on top of it.
                then run the path lines and they all snap correctly.
                works for me.
                • vpt.se
                  vpt.se commented
                  R1 or R2?
                  paddingpadding
