Now that I have my part transformed correctly according to XYZ I need to located the CAD part according to it's location on the machine. Essentially I want to avoid to the "Move Location Outside of Range" warning.
Translating CAD part location to Real world part location on CMM.
I have always (mostly) used a manual point at the CMM on the part.
ALN that point to XYZ origin. (use a pt that logically works and your Trihedron vectors are OK from your model)
Go to DCC and go to it......
ALN and prehit/retract and clearplane with generous amount. That gets your part aligned FIRST time. ---> (Level/Rotate/Origin)
Then let the CMM do it again to precisely align it.
Off you go.....and season to taste.
If you have good fixtures and setup images for the operator, once you have done the above, you're able to mask (mark) the manual point and Bob's your uncle.
- 1 like
by Numbers GameI occasionally insert the machine into the graphics window for the sake of visualising how my setup will look. However, none of my parts have regular...
09-09-2016, 11:19 AM -
by sscandlonCurrently to check a certain part I have to manually measure the planes and then run the program to relate the part to its placement on the machine and...
03-21-2019, 12:33 PM -
I have been reading and reading (and re-reading) the many posts on here dealing with iterative alignments and am still not getting the breakthrough I...
02-29-2008, 08:34 AM -
by quadman21Ok, so what I want to know is if I can change my origin on the cad model to match my CMM set up? I don't want to use CAD=Part right now because my cmm...
01-25-2008, 11:43 AM -
by mplaceI'm a newbie in the world of PC-Dmis and I'm stuck on a simple alignment. As you can see by the screenshot, I can't seem to get the part to match the...
11-28-2018, 10:06 AM -
