2020 R2 release
    I've been working with it during the technical preview. I really like it.
      List of Fixes (1)
      Application Errors
      • PCD-133290 - Fixed an application error that occurred when you calibrated a
      vision probe and the machine interface settings were incorrect.
      • PCD-146292 - Fixed an application error that occurred when you inserted the
      Ole Object and selected the Microsoft Word document in the Custom Report
      Editor window.
      • PCD-162303 - Fixed an application error that occurred when you tried to edit
      a Form Report that contained an error script.
      • PCD-175692 - Fixed an application error that occurred when you edited an
      Analysis View object from the main report editor.
      • PCD-185384 - Fixed an application error that occurred when you pressed
      Cancel in the Extended Sheet Metal Features dialog box after you
      minimized and then restored PC-DMIS.
      • PCD-185750 - Fixed an application error that occurred when you clicked No
      in the Qualification Tool Moved message box prompt during the calibration
      of a probe.
      • PCD-186821 - Fixed an application error that occurred when the
      Application.Exit automation command closed PC-DMIS.
      • PCD-190155 - Fixed an application error that occurred when you exported
      vision features to an .xml file through File | Export | XML.
      • PCD-190622 - Fixed an application error that occurred when you typed a nonexisting
      Mesh ID for the MESH/OPER command in the Edit window.
      • PCD-190730 - Fixed an application error that occurred when you tried to exit
      from the Custom Report window and clicked View Report Mode in the
      Reporting toolbar.
      • PCD-193937 - Fixed an application error that occurred when you selected a
      GB polygon feature on the CAD model and clicked Create in the Extended
      Sheet Metal Features dialog box.
      Auto Features
      • PCD-145939 - Fixed an issue with incorrect avoidance moves when you used
      the self-center point strategy for auto vector points.
      • PCD-183575 - Fixed an issue where Auto Feature scanning strategies didn't
      support speed correctly when you defined it as a percentage of maximum
      speed.
      Automation
      • PCD-114827 - Fixed an issue where PC-DMIS wouldn't create a Constructed
      Circle (Cone) through automation.
      • PCD-114828 - Fixed an issue where PC-DMIS wouldn't create a Constructed
      Circle (Sphere) through automation.
      • PCD-114830 - Fixed an issue where PC-DMIS wouldn't create a Constructed
      Circle (Cylinder) through automation.
      • PCD-164229 - Fixed an issue where the command inserted through
      automation were incorrectly located in a measurement routine.
      • PCD-186103 - Fixed an automation issue where Inspect opened an offline
      measurement routine when you closed and immediately opened a
      measurement routine. This also prevented PC-DMIS from sending the status
      messages from the pointcloud to automation.
      CAD
      • PCD-148194 - Fixed an issue where PC-DMIS would incorrectly read in data
      from imported ASCII files.
      • PCD-173512 - Updated the look of the Virtual Machine models for Global S
      and Optiv 3-2-2.
      • PCD-176947 - Fixed an issue where PC-DMIS doesn't change the name of a
      feature when you referenced the feature as a variable.
      • PCD-179359 - Fixed an issue where PC-DMIS was not able to correct some
      surfaces when you clicked Fix Surface Vectors in the CAD Vectors dialog
      box.
      • PCD-183534 - Fixed an issue where PC-DMIS generated path lines only for
      the last feature when you selected Operation | Graphic Display Window |
      Collision Detection.
      • PCD-185756 - Fixed an issue where PC-DMIS showed incorrect probe
      positions when displayed in the Settings window (View | Other Windows |
      Settings Window).
      • PCD-186451 - Fixed an issue where PC-DMIS failed to clear the feature list
      when you selected new Geometric Tolerance in the XactMeasure GD&T
      dialog box.
      • PCD-188562 - Fixed an issue where the Edit window was disabled when you
      imported the CAD model and select File | Operations | Mirror.
      • PCD-188622 - Fixed an issue where PC-DMIS imported the CAD model even
      when you clicked Cancel in the merge information message box.
      • PCD-190202 - Fixed an issue where path lines were drawn to an incorrect
      location in the first feature when you turned on Quick Path.
      CMM
      • PCD-170663 - Fixed a hardware crash that occurred when an invalid tip was
      created for a probe.
      • PCD-179600 - Fixed an issue where the Laser working area was moved off
      the feature's center when you changed the Zoom settings in the Auto
      Feature dialog box.
      • PCD-190141 - Fixed an issue with I++ interface where PC-DMIS doesn't filter
      points with quality tags when you performed scan.
      • PCD-194939 - Fixed an issue with the I++ DME client where indexing head
      support was incorrect.
        List of Fixes (2)
        Dual Arm
        • PCD-96960 - Fixed an issue where an extra empty line was added in the
        .Results file of the Arm2 probe when PC-DMIS appends new results to the
        same file.
        Extended Sheetmetal Features
        • PCD-177908 - Fixed an issue where PC-DMIS showed incorrect results when
        you calculated ESF features with and without actual thickness.
        • PCD-184370 - Fixed an issue where the Edit window showed LASER
        commands as CONTACT commands when you created the ESF Laser
        features (VWMP).
        • PCD-184380 - Fixed an issue where PC-DMIS showed an incorrect error
        message when you edited the AA and BK ESF features.
        • PCD-185289 - Fixed an issue where PC-DMIS created a badly formatted .xml
        file when you exported ESF laser features.
        • PCD-185378 - Fixed an issue where PC-DMIS showed an error message
        when you tried to extract a CB (VWMP) feature.
        • PCD-189504 - Fixed an issue where the list of failed features was not
        complete in the output file when you executed a measurement routine with the
        ONEERROR/LASER,SKIP command.
        Home Page
        • PCD-165660 - Fixed an issue where a folder wouldn't open when you tried to
        open it from the Favorites section of the Home page.
        • PCD-185449 - Fixed an issue where an incorrect selection of menu items
        occurred on the Home page when you hovered your mouse over a tile and
        expanded the menu items.
        HTML5 Help
        • PCD-159970 - Fixed an issue where the Settings Editor failed to launch the
        Help file when you clicked the Help button or pressed F1.
        • PCD-171217 - Fixed an issue where the registry entries were not referenced
        consistently when you viewed the Settings Editor Help file.
        • PCD-171500 - Fixed an issue where the Back to Top link was not visible in
        the footer of the Help file.
        • PCD-178129 - Improved the Basic help to include information and an example
        on how to use the Picture control in the Basic Script Editor.
        • PCD-178130 - Added an example for the Put statement in the Basic Help.
        • PCD-181114 - Fixed an issue where a context mapping link dosen't show the
        correct topic when you pressed F1 in the Insert ActiveX Control dialog box.
        • PCD-184982 - Added a link to the GETTRACEVALUE() function from the
        "Inserting TRACEFIELD Commands" topic.
        • PCD-188326 - Fixed an issue where localized release notes were not
        accessible when you clicked Help | Release Notes.
        • PCD-192020 - Fixed an issue on the public website
        (https://docs.hexagonmi.com) where IE 11 couldn't show language contents
        on the main page, and it couldn't display the privacy policy page.
        • PCD-192505 - Fixed an issue in the Settings Editor documentation where the
        topic listed an incorrect default version for the Release registry entry under
        the Catia5 section.
        • PCD-193321 - Removed the duplicated registry entry topics from the DCI
        Help and linked them to the existing topics in the Settings Editor Help.
        Laser
        • PCD-98072 - Fixed an issue where the Filter area was cropped when you
        opened the Auto Features dialog box for Laser Surface point.
        • PCD-169323 - Fixed an issue where the box-selection of Laser Auto Features
        was not done in the current view when you extracted or measured it without
        CAD.
        • PCD-180953 - Fixed an issue where the MOVE/CLEARPLANE command was
        not inserted when you selected Insert | Scan | Section Cut.
        • PCD-184500 - Fixed an issue where PC-DMIS showed an incomplete
        warning message when you performed a tip calibration of the HP-L 10.6
        sensor.
        • PCD-187791 - Fixed an issue where the surfaces were skipped. This caused
        incomplete scans when you created a scan with CAD surfaces.
        • PCD-190079 - Fixed an issue when you created offline laser scans with an
        HP-L probe, and then ran the program online. The scans were observed at
        incorrect locations after you execute the scan in inch units.
        • PCD-194376 - Fixed an issue where PC-DMIS didn't create a point pair
        alignment when you clicked on points on the CAD model.
        Pointcloud
        • PCD-181687 - Fixed an issue where the position of the colormap min or max
        annotation points were updated when you executed a new pointcloud data.
        Added the ColorMapKeepMinMaxLabelPosition registry entry so that the
        min or max label position always stays the same.
        • PCD-183066 - Fixed an issue where PC-DMIS would hang when a huge size
        COP feature was selected in the Construct Feature dialog box.
        • PCD-185349 - Fixed an issue where the CALIPER command was not created
        properly when you saved a measurement routine to previous versions.
        • PCD-185747 - Fixed an issue where PC-DMIS took more time to export a
        pointcloud file than usual when you exported a psl file.
        • PCD-187890 - Fixed an issue where the Colormap Gradient Scale was not
        shown in the Graphic Display window when you loaded a different scale
        profile that wasn't the default one from the Profiles Manager dialog box.
        • PCD-188888 - Fixed an issue where the Thickness Colormap scale values
        were incorrect in the Mesh Operator dialog box when you have not marked
        the Compare to CAD check box.
        • PCD-194875 - Fixed an issue where PC-DMIS didn't create annotation points
        to a selected CAD face for a Point Colormap when you marked the Create
        annotation points check box in the Pointcloud Operator dialog box.
        Portable
        • PCD-31797 - Fixed an issue where tracker commands and modes were out of
        sync when you pressed the button or selected a menu item to switch the
        modes.
        • PCD-163802 - Fixed an issue where scan points were not visible real-time
        when read into a COP during a manual scan from the Manual Freeform
        dialog box.
        • PCD-163426 - Fixed an issue where PC-DMIS wouldn't save the IP address
        for the tracker in the leicalmf machine interface Setup dialog box when you
        clicked OK without clicking Apply.
        • PCD-174981 - Removed the SMXLaser Faro Tracker option from the Select
        default portable interface list in the PC-DMIS installer.
        • PCD-183258 - Fixed an issue where the probe moved to a different location
        when you created a dual- arm measurement routine and looped features on
        arm 2 only.
        Protect
        • PCD-186710 - Fixed an issue where Protect Viewer logged the changes of
        the QuickFeature even when you cancelled the QuickFeature widget.
        • PCD-193532 - Fixed an issue where PC-DMIS allowed you to certify the
        same measurement routine multiple times when no features or dimensions
        were available in the measurement routine.
        Reporting
        • PCD-137730 - Fixed an issue with the Form Editor option in the View menu.
        • PCD-154348 - Fixed an issue where the labels in the custom report didn't
        follow the selected Number of decimal places that were defined in the
        Setup Options dialog box.
        • PCD-178970 - Fixed an issue where the Excel Form Report file was empty
        when the Excel Form Report command was in a sub-routine.
        • PCD-183886 - Fixed an issue where PC-DMIS showed no error message for
        the append mode in the Excel Form Report when you opened the Excel Form
        Report file and continued execution.
        Scanning
        • PCD-149994 - Fixed an issue for both Laser and Contact probes where the
        Insert | Scan menu options were enabled even when the tip was not loaded.
        User Interface
        • PCD-177024 - Fixed an issue where the Temperature dialog box doesn't
        show the proper text when you used the Dark Theme.
        • PCD-183814 - Fixed an issue where incorrect probe angles were shown in
        the Add Angles dialog box when you added new tips from CAD.
        Vision
        • PCD-190250 - Fixed an issue where the Optical value on the Magnification
        tab in the Probe Toolbox dialog box was changed when you closed and
        reopened the measurement routine.
        • PCD-191441 - Fixed an issue that occurred when you didn't center the
        calibration slide rectangle at the beginning of the pixel size calibration, it
        caused distortion calibration failure after PC-DMIS prompts you to retry the
        calibration.
        • PCD-194676 - Fixed an issue where the Vision 2D profile feature showed
        incorrect deviation result when you marked the Include CAD check box in the
        Open dialog box.
          Originally posted by JEFMAN View Post
          List of Fixes (2)
          Open dialog box.
          That sounds like a familiar issue. Am I correct sealevel ?
          • Benedictj1
            Benedictj1 commented
            This is build 186. I am running 187 from the Tech Preview...???
          • Don Ruggieri
            Don Ruggieri commented
            copied from the Tech Preview Forum -
            That's my fault, I apologize. You'll need to uninstall the Tech Preview build (#187) and install the release (#186). Let me explain
            I built the Release (#186) nearly two weeks ago. This allows time to prepare marketing materials and more, internally. Then, after that, I built the same software with a different label (Pre-Release) (#187). I wanted to provide the same functions to our Tech Preview partners. The problem now is that it won't let you install 186 over 187. In retrospect I should have done it in the opposite order, I was under time constraints to get the Release build to our internal partners.
          Hats off to the dev team/s, impressive fix list!
          PC-DMIS CAD++ 2o19 R1 SP11
            Export excel form report. SIZE dimension is not showing DEV. Other dimensions do. Wont show lower tolerance either.
            • Don Ruggieri
              Thank you BenedictJ1, please (everyone) post such issues each in their own thread, it will make it easier to follow.
            K.
            I will put "2020 R2 RELEASE" in the subject when I post?? Or is their a naming convention you prefer to keep everything orderly? Can you create a place like the tech preview just for bug tracking for the release to keep all of this?
            • Don Ruggieri
              If you feel it is specific or new to 2020 R2, then go ahead and put that version reference in the title. If it is a general issue, then no need for a specific title
            Indeed Barry.
            For as long as I have used the Vision 2D profile, there was always something to irritate. But...in release 2018 R2 the 2D profile actually behaved (for selecting CAD points to create the profile) as opposed to the nonsense up to/including 2018 R1 releases. Props to Vision product owner Neil Ryan for all the efforts to make Vision better but....
            I have never attained the profile to report a tolerance of .0000 OFFline to CAD (with Min/Max) for every program using the camera. The CAD model family reported .0000 every time using OFFline styli.
            With a profile tolerance of .002|a|b|c and .0001 to .0002 reported OFFline, I was not very confident to use Vision for our customer. Although, our company was using 50x mylars on a comparator - which were even more bogus/subjective.
            I can't play with 2020 R2 since my SMA expired on Halloween of 2019, but hope PCD-194676 has helped you Mr.bfire85
