How to calculate true position using variables and expressions
  • How to calculate true position using variables and expressions
    I am new to variables and expressions. I cannot find what i'm looking for in the help index. Does anyone know how to do this?
    In the Edit Window, type ASSIGN and press TAB. You will have a command "ASSIGN/V1=0". Press F9 on the command, and click "Assign From...". This will take you to the Expression Builder which is a great place to start looking around.
    https://docs.hexagonmi.com/pcdmis/20...rch=expression
      Jacob, i've been there but havent had any luck creating a true position calculator. i was hoping someone here has done or tried to do the same thing.
      • Mike Ruff
        Mike Ruff commented
        Why not just use Insert> Dimension> Position? Why create extra work for yourself unnecessarily?
      Depending on the axes that you are evaluating your positional tolerance in, let’s say X and Y, you would assign deviation variables, dx and dy, respectively, as
      ASSIGN/DX=FEAT.X - FEAT.TX
      ASSIGN/DY=FEAT.Y - FEAT.TY
      And you would calculate your positional error as
      ASSIGN/POS=2*SQRT(DX^2 + DY^2)
      You have to be sure that your active alignment matches your DRF exactly or this won’t work. Also, as has been mentioned, if you have the tools to properly compute a positional error using the rules of your applicable standard (XactMeasure), then you should do that.
      What is your reason for attempting this manually through variables?
      • vpt.se
        vpt.se commented
        Also, this calculation won't include the theo/meas vector...
      • JacobCheverie
        JacobCheverie commented
        vpt.se Very good point, this would only apply in a 2D case. Thank you.
      I have a part that has four rails.(imagine a dvd rack) the drawing is treating the inside of the four rails like a circle when it isn't. the rails are actually square. i've tried constructing a circle from a point on each rail but pc dmis isnt having it so i wanted to use the deviation of the points coming from center ( rotating my alignment accordingly) and calculate a true position with the worst two deviations. sounds like alot because it is.
      • neil.challinor
        neil.challinor commented
        Have you tried measuring them as square slots?
      the shape of the feature collectively wouldnt be square, it would be circle but PC DMIS wont recognize it as a circle. I did come up with a way to calculate the true position based off of what Jacob commented on above. thank you guys for your help.
