Need help with do loop with a count
  • Need help with do loop with a count
    So i have 196 features to program, they will all require the same 7 points, I have a variable I am going to use for each axis, the vectors will be the same. I have seen a program before where it ran through and said on loop 1 use this variable count list 1, on loop 2 use variable count list 2, and so on. then I can program the loop using all the same variables because it will pull them from a count.
    I know i will need to put the variables in order from block / COUNT 1, slot 1-variables, COUNT 2, slot 2 varibales. But I cant figure out when using the DO LOOP, how do i say which block of variables to use in which loop number.
    $$ NO,
    ASSIGN/SLOT_D=0.0170
    ASSIGN/SLOT=SLOT_D/2
    $$ NO,
    ASSIGN/SLOT_1=0.1550
    ASSIGN/SLOT_2=0.1551
    ASSIGN/SLOT_3=0.1551
    $$ NO,
    ASSIGN/Y1=0.0009
    ASSIGN/Y2=-0.0010
    ASSIGN/Y3=0.0010
    $$ NO,
    ASSIGN/XOFF=-0.2005
    ASSIGN/X1=19.5488
    ASSIGN/X2=X1-XOFF
    ASSIGN/X3=X2-XOFF
    $$ NO,
    ASSIGN/SLOT_Z=-0.0050
    $$ NO,
    $$ NO,
    PNT_01 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-X1,-0.14015,0.132999>,<0,1,0>
    ACTL/<-19.5488,-0.14015,0.132999>,<0,1,0>
    TARG/<-X1,-0.14015,0.132999>,<0,1,0>
    SNAP=NO
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=NO
    PNT_02 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-X1,0.14015,0.13994>,<0,-1,0>
    ACTL/<-19.5488,0.14015,0.13994>,<0,-1,0>
    TARG/<-19.5488,0.14015,0.13994>,<0,-1,0>
    SNAP=NO
    PNT_03 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-X1,0.022,ZERO>,<ZERO,ZERO,ONE>
    ACTL/<-19.5488,0.022,0>,<0,0,1>
    TARG/<-X1,0.022,ZERO>,<ZERO,ZERO,ONE>
    SNAP=NO
    PNT_04 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-X1,Y1-SLOT,SLOT_Z>,<ZERO,ONE,ZERO>
    ACTL/<-19.5488,-0.0076,-0.005>,<0,1,0>
    TARG/<-X1,Y1-SLOT,SLOT_Z>,<ZERO,ONE,ZERO>
    SNAP=NO
    PNT_05 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-X1,Y1+SLOT,SLOT_Z>,<ZERO,-ONE,ZERO>
    ACTL/<-19.5488,0.0094,-0.005>,<0,-1,0>
    TARG/<-X1,Y1+SLOT,SLOT_Z>,<ZERO,-ONE,ZERO>
    SNAP=NO
    PNT_06 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-X1-SLOT_1/2,Y1,SLOT_Z>,<ONE,ZERO,ZERO>
    ACTL/<-19.6263,0.0009,-0.005>,<1,0,0>
    TARG/<-X1-SLOT_1/2,Y1,SLOT_Z>,<ONE,ZERO,ZERO>
    SNAP=NO
    PNT_07 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
    THEO/<-X1+SLOT_1/2,Y1,SLOT_Z>,<-ONE,ZERO,ZERO>
    ACTL/<-19.4713,0.0009,-0.005>,<-1,0,0>
    TARG/<-X1+SLOT_1/2,Y1,SLOT_Z>,<-ONE,ZERO,ZERO>
    SNAP=NO
    $$ NO,
    -riley Lawlor
    Southern California
    Aerospace CNC Machinery
    I tried doing this as a test for the first 3 of 196, but it isn't working correct.
    $$ NO,
    $$ NO,
    ASSIGN/COUNTER=0
    ASSIGN/X1=19.5488
    ASSIGN/XOFF=0.2005
    DO/
    ASSIGN/COUNTER=COUNTER+1
    IF/COUNTER==1
    ASSIGN/X1=19.5488
    ASSIGN/Y1=0.0009
    END_IF/
    IF/COUNTER==2
    ASSIGN/SLOT_1=0.1551
    ASSIGN/X1=X1-XOFF
    ASSIGN/Y1=-0.0010
    END_IF/
    IF/COUNTER==3
    ASSIGN/X1=X1-XOFF
    ASSIGN/Y1=0.0010
    END_IF/
    $$ NO,
    $$ NO,
    $$ NO,
    $$ NO,
    THEO/<-X1,-0.14015*1,0.1400*1>,<ZERO,ONE,ZERO>
    ACTL/<-19.3483,-0.14015,0.14>,<0,1,0>
    TARG/<-X1,-0.14015,0.1400*1>,<ZERO,ONE,ZERO>
    SNAP=NO
    THEO/<-X1,0.14015*1,0.1400*1>,<ZERO,-ONE,ZERO>
    ACTL/<-19.3483,0.14015,0.14>,<0,-1,0>
    TARG/<-X1,0.14015*1,0.1400*1>,<ZERO,-ONE,ZERO>
    SNAP=NO
    ACTL/<-19.3483,0.022,0>,<0,0,1>
    SNAP=NO
    ACTL/<-19.3483,-0.0075,-0.005>,<0,1,0>
    SNAP=NO
    ACTL/<-19.3483,0.0095,-0.005>,<0,-1,0>
    SNAP=NO
    ACTL/<-19.42585,0.001,-0.005>,<1,0,0>
    SNAP=NO
    ACTL/<-19.27075,0.001,-0.005>,<-1,0,0>
    SNAP=NO
    $$ NO,
    UNTIL/COUNTER>=3
    $$ NO,
    $$ NO,
    ROUTINE/END
    $$ NO,
    -riley Lawlor
    Southern California
      First, as you use only SLOT_1/2, I would assign SLOT_1 = (different values)/2 directly.
      I don't see ASSIGN/ZERO and ONE.
      You write twice ASSIGN/COUNT=COUNT+1 in the loop, at the start and at the end, so you start COUNT=1, then COUNT=3 and never count = 2...
        The attached pictures don't match each other or is it just me? One is zig-zagging and the other is slots in-line. I'll pick the ziggy-zag for my example... give me a minute and I'll pump something out.
        PcDmis 2015.1 SP10 CAD++
        Global 7-10-7 DC800S
          I would create a simple loop from 1 to 196...
          Not sure answering to all your questions of both posts..., hope this helps.
          ASSIGN/COUNTER=0
          ASSIGN/X1=19.5488
          ASSIGN/XOFF=0.2005
          $$ NO,
          V1 =LOOP/START,ID=YES,NUMBER=196,START=1,SKIP=,
          OFFSET:XAXIS=X_offset,YAXIS=0,ZAXIS=0,ANGLE=0
          $$ NO,
          IF/V1==1
          ASSIGN/X1=19.5488
          ASSIGN/Y1=0.0009
          END_IF/
          IF/V1>1
          ASSIGN/X1=X1-XOFF
          ASSIGN/Y1=-0.0010
          END_IF/
          IF/2*ROUND(V1/2)<>V1
          ASSIGN/Y1=0.0010
          END_IF/
          $$ NO,
          $$ NO,
          $$ NO,
          $$ NO,
          SNAP=NO
          SNAP=NO
          SNAP=NO
          SNAP=NO
          SNAP=NO
          SNAP=NO
          SNAP=NO
          ASSIGN/PT_X[V1]=(PNT_04.X+PNT_05.X+PNT_06.X+PNT_07.X)
          ASSIGN/PT_Y[V1]=(PNT_04.Y+PNT_05.Y+PNT_06.Y+PNT_07.Y)
          ASSIGN/PT_Z[V1]=(PNT_04.Z+PNT_05.Z+PNT_06.Z+PNT_07.Z)
          ASSIGN/PT_TX[V1]=(PNT_04.TX+PNT_05.TX+PNT_06.TX+PNT_07.TX)
          ASSIGN/PT_TY[V1]=(PNT_04.TY+PNT_05.TY+PNT_06.TY+PNT_07.TY)
          ASSIGN/PT_TZ[V1]=(PNT_04.TZ+PNT_05.TZ+PNT_06.TZ+PNT_07.TZ)
          ASSIGN/L1[V1]=(PNT_07.X-PNT_06.X)-(PNT_07.TX-PNT_06.TX)
          MID_PNT=GENERIC/POINT,DEPENDENT,CARTESIAN,$
          NOM/XYZ,<PT_TX[V1],PT_TY[V1],PT_TZ[V1]>,$
          MEAS/XYZ,<PT_X[V1],PT_Y[V1],PT_Z[V1]>,$
          NOM/IJK,<0,0,1>,$
          MEAS/IJK,<0,0,1>,$
          $$ NO,
          LOOP/END
          $$ NO,
          SCN1 =FEAT/SET,CARTESIAN
          THEO/<0,0,0>,<0,0,1>
          ACTL/<0,0,0>,<0,0,1>
          CONSTR/SET,BASIC,MID_PNT[1..196],,
          LIN1 =FEAT/LINE,CARTESIAN,UNBOUNDED,NO
          THEO/<0,0,0>,<1,0,0>
          ACTL/<0,0,0>,<1,0,0>
          CONSTR/LINE,BF,SCN1
          ASSIGN/SLOPE=(LIN1.J/LIN1.I)
          ASSIGN/LENGTH_ERROR=SUM(L1)/196
          V2 =LOOP/START,ID=YES,NUMBER=196,START=1,SKIP=,
          OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=0
          ASSIGN/VECT1=CROSS(LN1.IJK,(actual_alignment_name).ZAXIS)
          ASSIGN/PT1="MID_PNT["+V2+"]"
          ASSIGN/E1[V2]=DOT(PT1.XYZ-LN1.XYZ,VECT1)
          LOOP/END
          ASSIGN/ABS_ERROR=SUM(ABS(E1))/196
          ASSIGN/S1=SUM(E1)/196
          ASSIGN/S2=E1-S1
          ASSIGN/S3=S2^2
          ASSIGN/STD_DEV=SQRT(SUM(S3)/195)
          $$ NO,
          ROUTINE/END
          $$ NO,
          • rtlawlor
            rtlawlor commented
            Jeff, I have another post about trying to solve to equation for this in pcdmis, someone tagged you to it this morning. THink you can take a look at it and see if your mathlete skills can help us!
            Would be greatly appreciated.
          • JEFMAN
            JEFMAN commented
            rtlawlor : JacobCheverie is right, M and B are ok by this way !
          SNAP=NO
          Does -X1 actually work? I'm thinking it's always going to give zero. You want X1*-1 if you're trying to negate the value.
          • Kp61dude!
            Kp61dude! commented
            It works to negate by a "-" and to make positive use ABS(variableName) or the trusty (one you mentioned) variableName*-1 to toggle it's axis.
          • RandomJerk
            RandomJerk commented
            Kp61dude! - I'm way too old school - in any programming language I've used in the past that would throw an error, you simply couldn't negate a variable by throwing a negative sign in front of it.
          • Kp61dude!
            Kp61dude! commented
            for sure! some syntax out there aren't very forgiving.
          I cant do a simple loop because the Y value is changes everyone loop, and its not a simple progressive change. they range from -0.0009 to 0.0261 and there is no rime or reason to its progressive change.
          -riley Lawlor
          Southern California
            I have to do this for 196 values. I have seen a program that was a DO LOOP and in the counter it said for loop1 use these variables, for loop2 use this variables, but I don't know how to separate each variables per loop. I tried while & if statements and I couldn't get it to work. Its only 3 variables that change each time. The X, axis, the Y axis, and the slot length. But the x value is a progressive 0.2005.
            -riley Lawlor
            Southern California
              In this case, I believe that you should write values in a text file, and read them as assignments, the prog will be more readable than if you have 196 cases !!!!!!!!!
                Here's one example. Like JEFMAN said having 196 cases is bonkers!!! There has to be a rhyme to that Y axis or at least get it good enough to get good probe hits.
                            ASSIGN/CNTR.2=0
                            ASSIGN/OFFSET.X=2.966
                            ASSIGN/OFFSET.Y=-.394
                            ASSIGN/OFFSET.Z=.085
                            ASSIGN/OFFSET.MLTPR=.085
                            ASSIGN/AOFFSETS.Z=ARRAY(.045,.130,.215,.300,.385,.470,.555)
                            ASSIGN/MOVEPNT.X=OFFSET.X
                            ASSIGN/MOVEPNT.Y=-.2
                            ASSIGN/MOVEPNT.Z=.555
                            ASSIGN/LOOPSETTINGS.TOG=0
                            ASSIGN/FEATLOC.X=2.966
                            ASSIGN/FEATLOC.Y=-.394
                            ASSIGN/FEATLOC.Z1=0
                            ASSIGN/FEATLOC.Z2=0
                            ASSIGN/FEATLOC.ZCALC1=.580
                            ASSIGN/FEATLOC.ZCALC2=.530
                            DO/
                $$ NO,
                            toggle settings after n loops
                            IF/LOOPSETTINGS.TOG==0 AND CNTR.2>6
                              ASSIGN/MOVEPNT.Z=.085
                              ASSIGN/OFFSET.Z=0
                              ASSIGN/FEATLOC.X=2.706
                              ASSIGN/FEATLOC.Y=-.094
                              ASSIGN/FEATLOC.ZCALC1=.07
                              ASSIGN/FEATLOC.ZCALC2=.02
                              ASSIGN/LOOPSETTINGS.TOG=1
                            END_IF/
                $$ NO,
                            settings not toggled. Loop count < n
                              ASSIGN/OFFSET.Z=OFFSET.MLTPR * CNTR.2
                              ASSIGN/FEATLOC.Z1=FEATLOC.ZCALC1 - OFFSET.Z
                              ASSIGN/FEATLOC.Z2=FEATLOC.ZCALC2 - OFFSET.Z
                            END_IF/
                            ELSE/
                  $$ NO,
                              settings toggled. Loop count > n
                              ASSIGN/=AOFFSETS.Z[(CNTR.2+1)-7]
                              ASSIGN/OFFSET.Z=OFFSET.MLTPR * ((CNTR.2)-7)
                              ASSIGN/MOVEPNT.Z=OFFSET.Z*2+AOFFSETS.Z[1]
                              ASSIGN/FEATLOC.Z1=FEATLOC.ZCALC1 + OFFSET.Z
                              ASSIGN/FEATLOC.Z2=FEATLOC.ZCALC2 + OFFSET.Z
                              ASSIGN/MOVEPNT.X=2.9
                              ASSIGN/MOVEPNT.Y=-.094
                            END_ELSE/
                            MOVE/POINT,NORMAL,<MOVEPNT.X,MOVEPNT.Y,MOVEPNT.Z - OFFSET.Z>
                PNT61      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                            THEO/<FEATLOC.X,FEATLOC.Y,FEATLOC.Z1>,<0,0,-1>
                            ACTL/<2.706,-0.094,0.58>,<0,0,-1>
                            TARG/<FEATLOC.X,FEATLOC.Y,FEATLOC.Z1>,<0,0,-1>
                            SNAP=NO
                            SHOW CONTACT PARAMETERS=YES
                              AVOIDANCE MOVE=NO,DISTANCE=0.5
                            SHOW HITS=NO
                PNT62      =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                            THEO/<FEATLOC.X,FEATLOC.Y,FEATLOC.Z2>,<0,0,1>
                            ACTL/<2.706,-0.094,0.53>,<0,0,1>
                            TARG/<FEATLOC.X,FEATLOC.Y,FEATLOC.Z2>,<0,0,1>
                            SNAP=NO
                            SHOW HITS=NO
                            ASSIGN/OFFSET.ZMID=(PNT61.Z+PNT62.Z)/2
                $$ NO,
                            features run only if loop settings toggle is true
                  $$ NO,
                              features inside this if logic is .005 offset CAD to comply with drawing.
                PNT63        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.8855,-0.3311,OFFSET.ZMID>,<0.9063078,-0.4226183,0>
                              ACTL/<2.8855,-0.3311,0.045>,<0.9063078,-0.4226183,0>
                              TARG/<2.8855,-0.3311,OFFSET.ZMID>,<0.9063078,-0.4226183,0>
                              SNAP=NO
                              SHOW HITS=NO
                PNT64        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.7864,-0.6148,OFFSET.ZMID>,<0.9723699,-0.2334454,0>
                              ACTL/<2.7864,-0.6148,0.045>,<0.9723699,-0.2334454,0>
                              TARG/<2.7864,-0.6148,OFFSET.ZMID>,<0.9723699,-0.2334454,0>
                              SNAP=NO
                              SHOW HITS=NO
                PNT65        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.7459,-0.9127,OFFSET.ZMID>,<0.9993908,-0.0348995,0>
                              ACTL/<2.7459,-0.9127,0.045>,<0.9993908,-0.0348995,0>
                              TARG/<2.7459,-0.9127,OFFSET.ZMID>,<0.9993908,-0.0348995,0>
                              SNAP=NO
                              SHOW HITS=NO
                PNT66        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.745,-1.075,OFFSET.ZMID>,<1,0,0>
                              ACTL/<2.745,-1.075,0.045>,<1,0,0>
                              TARG/<2.745,-1.075,OFFSET.ZMID>,<1,0,0>
                              SNAP=NO
                              SHOW HITS=NO
                PNT67        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.7459,-1.2373,OFFSET.ZMID>,<0.9993908,0.0348995,0>
                              ACTL/<2.7459,-1.2373,0.045>,<0.9993908,0.0348995,0>
                              TARG/<2.7459,-1.2373,OFFSET.ZMID>,<0.9993908,0.0348995,0>
                              SNAP=NO
                              SHOW HITS=NO
                PNT68        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.7615,-1.4067,OFFSET.ZMID>,<0.9890159,0.1478094,0>
                              ACTL/<2.7615,-1.4067,0.045>,<0.9890159,0.1478094,0>
                              TARG/<2.7615,-1.4067,OFFSET.ZMID>,<0.9890159,0.1478094,0>
                              SNAP=NO
                              SHOW HITS=NO
                PNT69        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.7961,-1.5732,OFFSET.ZMID>,<0.9659258,0.258819,0>
                              ACTL/<2.7961,-1.5732,0.045>,<0.9659258,0.258819,0>
                              TARG/<2.7961,-1.5732,OFFSET.ZMID>,<0.9659258,0.258819,0>
                              SNAP=NO
                              SHOW HITS=NO
                            END_IF/
                            ELSE_IF/LOOPSETTINGS.TOG==1
                PNT70        =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                              THEO/<2.711,-0.22,OFFSET.ZMID>,<0,1,0>
                              ACTL/<2.711,-0.22,0.555>,<0,1,0>
                              TARG/<2.711,-0.22,OFFSET.ZMID>,<0,1,0>
                              SNAP=NO
                              SHOW HITS=NO
                            END_ELSEIF/
                            RECALL/ALIGNMENT,INTERNAL,MAIN_ALN
                            MOVESPEED/ 80
                            MOVESPEED/ 125
                            ASSIGN/CNTR.2=CNTR.2 + 1
                            UNTIL/CNTR.2 > 13
                You may also want to consider creating a sub routine. Pass in XYZ as a pattern origin construction point and offset 7 points from that point and call your sub 196 times. I know...196 will require a lot of typing but hey calling a sub with parameters is still less work than 7pnts times 196 (1372 total points!).
                  I have no experience with subroutines though.
                  -riley Lawlor
                  Southern California
                  • neil.challinor
                    neil.challinor commented
                    Like JEFMAN says,
                    Create a text file that has the X, Y and slot length on one line for each slot - formatted something like this...
                    123,456,789
                    234,567,890
                    987,654,321
                    So you would end up with a comma separated text file that is 196 lines long - one line for each slot.
                    In PC-Dmis, read in the text file line by line within a loop and assign your read in values to variables that you use to measure each slot...
                     ASSIGN/COUNT=0
                    FPTR =FILE/OPEN,MY_TEXT_FILE.TXT,READ
                    DO/
                    V2 =FILE/READLINE,FPTR,{XVAL}+","+{YVAL}+","+{SLEN}
                        code to measure your slots here using XVAL, YVAL and SLEN variables
                    UNTIL/COUNT==196
                    FILE/CLOSE,FPTR,KEEP
                  THANK YOU!!!!!!!!!! I ended up doing it the hardest pay possible. I imported all the variables, but then they didn't want the slots measured at features because they wanted local alignments updated for the wave guide, plane, and the slot y axis.
                  PNT_001 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                  ACTL/<-19.549584,-0.139799,0.14121>,<0,1,0>
                  SNAP=NO
                  PNT_002 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                  ACTL/<-19.549877,0.140799,0.14006>,<0,-1,0>
                  SNAP=NO
                  PNT_E1 =FEAT/POINT,CARTESIAN,NO
                  THEO/<-19.5488,0,0.14>,<0,0,1>
                  ACTL/<-19.549731,0.0005,0.140635>,<-0.0000421,-0.0043341,0.9999906>
                  CONSTR/POINT,MID,PNT_002,PNT_001
                  A6 =ALIGNMENT/START,RECALL:SLOTS_DCC_CSY,LIST=YES
                  ALIGNMENT/TRANS,YAXIS,PNT_E1
                  ALIGNMENT/END
                  PNT_D1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                  THEO/<-X1,-0.022,ZERO>,<ZERO,ZERO,ONE>
                  ACTL/<-19.55003,-0.021264,-0.000316>,<0,0,1>
                  TARG/<-X1,-0.022,ZERO>,<ZERO,ZERO,ONE>
                  SNAP=NO
                  A8 =ALIGNMENT/START,RECALL:USE_ACTIVE_ALIGNMENT(A6),LIST=YES
                  ALIGNMENT/TRANS,ZAXIS,PNT_D1
                  ALIGNMENT/END
                  MOVE/CLEARPLANE
                  PNT_003 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                  THEO/<-X1,SY1-SR,-SLOT_Z>,<ZERO,ONE,ZERO>
                  ACTL/<-19.55002,-0.008406,-0.004386>,<0,1,0>
                  TARG/<-X1,SY1-SR,-SLOT_Z>,<ZERO,ONE,ZERO>
                  SNAP=NO
                  PNT_004 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                  THEO/<-X1,SY1+SR,-SLOT_Z>,<ZERO,-ONE,ZERO>
                  ACTL/<-19.550017,0.008758,-0.004778>,<0,-1,0>
                  TARG/<-X1,SY1+SR,-SLOT_Z>,<ZERO,-ONE,ZERO>
                  SNAP=NO
                  PNT_W1 =FEAT/POINT,CARTESIAN,NO
                  THEO/<-19.5488,0.0009,-0.005>,<0,0,1>
                  ACTL/<-19.550018,0.000176,-0.004582>,<-0.0000421,-0.0043341,0.9999906>
                  CONSTR/POINT,MID,PNT_003,PNT_004
                  A7 =ALIGNMENT/START,RECALL:USE_ACTIVE_ALIGNMENT(A8),LIST=YES
                  ALIGNMENT/TRANS,YAXIS,PNT_W1
                  ALIGNMENT/END
                  PNT_005 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                  THEO/<-X1+S1L/2,ZERO,-SLOT_Z>,<-ONE,ZERO,ZERO>
                  ACTL/<-19.471419,0.000139,-0.004893>,<-1,0,0>
                  TARG/<-X1+S1L/2,ZERO,-SLOT_Z>,<-ONE,ZERO,ZERO>
                  SNAP=NO
                  PNT_006 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
                  THEO/<-X1-S1L/2,ZERO,-SLOT_Z>,<ONE,ZERO,ZERO>
                  ACTL/<-19.626412,-0.000101,-0.00494>,<1,0,0>
                  TARG/<-X1-S1L/2,ZERO,-SLOT_Z>,<ONE,ZERO,ZERO>
                  SNAP=NO
                  PNT_L1 =FEAT/POINT,CARTESIAN,NO
                  THEO/<-19.5488,0,-0.005>,<0,0,1>
                  ACTL/<-19.548916,0.000019,-0.004917>,<-0.0000421,-0.0043341,0.9999906>
                  CONSTR/POINT,MID,PNT_005,PNT_006
                  RECALL/ALIGNMENT,INTERNAL,SLOTS_DCC_CSY
                  MOVE/CLEARPLANE
                  A9 =ALIGNMENT/START,RECALL:SLOTS_DCC_CSY,LIST=YES
                  ALIGNMENT/TRANS,XAXIS,PNT_L1
                  ALIGNMENT/END
                  MOVE/CLEARPLANE
                  x195
                  -riley Lawlor
                  Southern California
