I'm trying to start saving reports in RTF format so that I can edit out things like the calibration results and dimensions used for manufacturing but are not customer required dimensions. I saved a test report and even though I have the CMM report as text only I still can't highlight anything after I print it. I'm using PCD 2020 R1 and Word 2013.
Editing rtf report
There's a setting in the settings editor which I think you need to set to either 1 or 2 (default is 0 I believe).
Something like DONUTUSEAMYUNIRTF of something, but if you search for DONOTUSEAMY you'll find it.
Consult the help files for full information on the setting.
- 1 like
I entered DONUTUSEAMYUNIRTF in the search but nothing came up. What section is it in?Marty Dobson
Director of Quality
http://www.linkedin.com/in/mjdobson
PC-DMIS CAD V4.2 MR1 & V2011
PH10MQ
TP200
I figured it out. Its not DONUTUSEAMYUNIRTF its DONOTUSEMYUNIRTF.Marty Dobson
Director of Quality
PH10MQ
TP200
by jjewellOK, in ver 2013, the plain text report is NOT the old plain text report, like it used to be.
Bringing this new style report into word sucks....and...-
06-07-2014, 10:57 AM -
by skellyI'm saving the report file as an RTF and they are larger than expected. The report is text only, no header with Use Test Mode Dimensioning active and...
10-24-2011, 03:02 PM -
by LGDCMM3RDWas running 3.7, just recently switched to 4.2mr3. With 3.7 i was able to set printout format to text only. I could go to edit/preferences/edit window...
02-02-2010, 06:23 AM -
by quicklearnerHi,
I need help to solve the following.
I run PC DMIS 4.2.or reporting I use textonly.I saved all files in Rich format.After running...-
06-25-2010, 02:04 PM -
Customer wants a plain text RTF file. When I print a RTF in reports it is 50X bigger than when I print the edit window in RTF. I actually need the report...
05-13-2008, 03:13 PM -
