making a 5 way probe active
  • making a 5 way probe active
    I am building this probe that looks like a star (LSPX1H_M3_5WAY), but once I am done building it how do I make one or more of those connection active?
    When you choose the star probe, you will be able to choose which one that’s active.
    Darroll
    2018R2
      Here :
      ftp://ftp.wilcoxassoc.com/docs/
      Then How to docs,
      Then Defining star probe.zip
      ftp://ftp.wilcoxassoc.com/docs/How%20To%20Docs/
        The tips are numbered 1-5. Tip 1 will be the one pointing down. 2-5 are the side tips. Just choose the tip# the same way you choose the A and B angles.
        HTH
        PC-DMIS 2016.0 SP8
        Jeff
          HTH
          As long as you select them in that order. It gives the T# based on the order you select them. it's quite possible to really f*ck things up if you choose a random order.
            thank you
            I really appreciate the pictures , really helped out.
              Also in the program if you are using tip #3 (for example) you will select it as TIP/T3A0B0 Instead of TIP/T1A0B0
                Good point. If you have a 5way with just one probe added a the #4 position, it will be tip T1. For the last number of years I always add tiny styli in the unused tips so that the T# will always match the tip position. I will often add a comment in the program about which positions should actually have styli installed.
                PC-DMIS 2016.0 SP8
                Jeff
                • RandomJerk
                  RandomJerk commented
                  After you get it set, delete the tips that aren't actually there - it won't reset the T#
                Did you try this?
                • Douglas
                  Douglas commented
                  I am willing to bet pretty big money that he did not try that... you can have 10 to 1 odds as well
                I don't know it going to help... but you can try search on youtube PC-DMIS Star Probe. It may help.
                • gppcdmis
                  Using Star probe
                  by gppcdmis
                  I want to use a star probe but I have no idea how to : create one, pick components and also calibrate one.
                  I went to the CMM level 1 & 2...
                  08-16-2010, 02:02 PM
                • Msolito
                  5 way star Question
                  by Msolito
                  I need to use this CMM , And PH_6 head is only Moving in A0B0(use for floor Inspection)and they want to used for small part with holes in all direction...
                  08-18-2009, 11:32 AM
                • tnguyen
                  Star Probe
                  by tnguyen
                  Hi Everybody.
                  I am using SP600 with regular probe angles to measure everything. Now, I need to build a Star Probe for convenient in my part...
                  03-03-2007, 05:42 PM
                • Gussi
                  6+1 way customize starprobe
                  by Gussi
                  . I am using Pc-dmis 2013 pro, attached is 6+1 starprobe.
                  I am trying to build, and add it to the probe library, a 6+1 way star probe, because...
                  09-30-2015, 11:26 AM
                • tnguyen
                  Fixed star probe on probe file
                  by tnguyen
                  Hi everybody.
                  Today, I just buy a M2 Fixed Star probe. I tried to build it. But no luck.
                  When I set the 5way probe, then I don't...
                  03-14-2007, 06:39 PM
