ERROR MESSAGE "PUSHING A POINT"
  • ERROR MESSAGE "PUSHING A POINT"
    I started getting an error message during a circular move "ERROR CE ,S%1 ,TR_CE , 0x1400003a System error pushing a point in an" I can't see the rest of the message in the drop down (see attached). I know the probe is heavy (15.24 grams), but I'm only running at 5mm/sec to avoid false triggers. Any ideas?
    DeWain Hodge
    You can make that window bigger so you can see the whole text.
      I'll give it a try tomorrow, I doubt if I will get back to the part today. It's funny that the only way to clear the error though is to restart the controller.
      DeWain Hodge
        Depending on your controller... you could hit the E-Stop, clear it, disable/enable the probe (button on handheld) a bunch of times. If it works, then you've saved yourself a bunch of time not rebooting, if not it was worth a try.
        PcDmis 2015.1 SP10 CAD++
        Global 7-10-7 DC800S
          I know this is a very IT answer but when I have issues that I cant explain I always do a reset. It works most of the time.
          Please Join The Effort.
          https://www.pcdmisforum.com/forum/pc...o-metric/page2 (Comment #17)
            I finally got past the issue. It appears that when doing a circular move on an OD you have to go more than 5mm/sec. I bumped the speed to 15mm/sec and no more error. Though I get false triggers now when the probe is moving, but I can get past them.
            DeWain Hodge
              You can put in a lot of extra movespeed commands, slow it down for the moves, speed it up for the features.
                Does it have to be 15mm/sec? Could you find a half way mark that works and mitigates some false triggers?
                  I might could split the difference on the speed and try again, but these were just test samples and I have carbon fiber in the way.
                  DeWain Hodge
                  • Big Jeffers
                    Error Message
                    by Big Jeffers
                    When I Open Up Pcdmis I Get An Error Message Saying "communications Interrupted-attempting To Resynchronize".i Have Checked All The Connections...
                    08-18-2007, 05:22 AM
                  • wsneeden
                    Error in connect=0 message
                    by wsneeden
                    I am wondering if anyone has ever encountered this error message before....
                    When opening PCDMIS I receive an error message of 'error in...
                    06-03-2015, 08:34 AM
                  • Tested
                    Error message
                    by Tested
                    Has anyone seen or heard of this Error before. I did a edit on a long time running program and now before it starts it gives this error.'
                    12-11-2007, 07:14 AM
                  • bamlin
                    Error Message
                    by bamlin
                    I have two PCDemon seats... same versions on both (4.2MR1). When I run a program on Machine #1 and want to stop the program it gives me an "error...
                    01-13-2010, 12:46 PM
                  • Guest's Avatar
                    Error Message
                    by Guest
                    Has any one seen this Error message? If so what is going on? B&S ONE with PcDmis 3.7...
                    11-27-2007, 09:40 AM
