Suggestions Please!
  • Suggestions Please!
    Fun. So I have a cylinder that is dia. 4.243". On this cylinder there are 8 equally spaced spherical divots or "holes" that are called 8 x R .626 +.001/ -.000 tp .001 MMC. And the depth of the divots are controlled by the distance 3.038 +.000/-.002 from bottom of R .626 to bottom opposite R .626. And at the bottom of each R .626 there is an additional tiny divot that is called R.125 +.000/-.030 with a depth of .020 from the bottom of the tiny divot to the (now) theoretical bottom of the R .626 divot. I think I need some whiskey for my coffee this morning. HELP PLEASE!
    Well, I think that your best approach will be to measure each of the divots as spheres. Then, you need to calculate where the bottom of the divot is since you can't measure it since the other divot is there. I think you are going to have to do a little calculating here.
      Distance between two spheres ("subtract radius" checked)??
      F5         =GENERIC/SPHERE,DEPENDENT,RECT,OUT,$
                  NOM/XYZ,0,0,0,$
                  MEAS/XYZ,-200,0,0,$
                  NOM/IJK,0,0,1,$
                  MEAS/IJK,0,0,1,$
                  DIAMETER/0,25
      F6         =GENERIC/SPHERE,DEPENDENT,RECT,OUT,$
                  NOM/XYZ,0,0,0,$
                  MEAS/XYZ,200,0,0,$
                  NOM/IJK,0,0,1,$
                  MEAS/IJK,0,0,1,$
                  DIAMETER/0,25
      DIM DIST1= 3D DISTANCE FROM SPHERE F5 TO SPHERE F6, SUB_RADIUS  UNITS=IN ,$
      GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH
      AX   NOMINAL     +TOL       -TOL       MEAS        MAX        MIN        DEV      OUTTOL
      M      0.0000     0.0100     0.0100   375.0000   375.0000   375.0000   375.0000   374.9900 -------->
        Very good J. I guess you smelled the bait. Deleting an old post to keep your count down while allowing you to answer is clever. I must confess Goodluck put me up to trying to trick you into going over.
        This is the part I am programming right now, but I have handled such things before many times. My favorite part is the tp callout with no basic dims or datums associated, just tp .001 MMC. sigh!
        So now I am a demiguru, (again), and you can be too.
        P.S. this is RESOLVED, hi-jack away!
          May your radii measure properly and your probe always be clean...
            Congrats to you too!
              I thought with all the talks of Divits you were playing golf
              B&S Global 544
              Using 3.7mr3
              Peace
              Greg
                So he sort of fell for it then...
