Just a quick one,
Can anyone provide some coding with incorporating scan data into feature sets with certain parameters.
For example, the last 10 points in a scan in the set. I do not want to just hard wire the feature numbers in the set as the open linear scan points can differ from the generated offline scan to the online depending on the controller. Offline scan might give me 1245 points but when run online this might be 1299 points.
It would also be great if I could include points in a set between or above a certain coordinate. For example points between coordinates z - 10mm and z - 20mm of scan 1 go to into the feature set.
Thanks for looking
Thanks for looking
