Hi guys, I’m still fairly new to programming, I’ve been to the basic class so bare with me. How would I go about finding the position of the angled minor diameter, would I need to make a separate offset alignment for every hole I need to check?
Position of an angled thru hole
If you know the proper location and vector of the hole, CAD would help, then one alignment to the datums would suffice. Just make sure the deviation perpendicular to centerline option is on. If you are just programing to the print, then the best way would be to rotate and offset the alignment to make each hole X 0, Y 0. and square to the alignment. That's the old school method for angled holes, but with CAD it isn't needed.Last edited by Schrocknroll; 07-30-2020, 05:14 PM.PC-DMIS 2016.0 SP8
Jeff
- Likes 1
To add clarification to Schrocknroll statement, if you are using XactMeasure dimensioning with CAD then shifting/rotating the alignment is not strictly necessary (although a lot of people still prefer to do it anyway). If you are using legacy dimensioning - with or without a CAD model - then you MUST shift and rotate your alignment so that it is centred on the theoretical hole location and looking down the hole theoretical vector.
I don't use XactMeasure that much so I forgot about that option. Good point.
by pnwenz89All,
I am trying to measure a 4mm hole on a diameter. This hole has a positional tolerance of .2mm from a diameter. I do not have a CAD...-
06-01-2020, 02:10 PM -
by gdntnoviceCan someone share the manual section on how to program a composite position tolerance. Thanks.
04-17-2020, 12:17 AM -
by pnwenz89Problem: I have a shaft between centers with a 4mm hole on the diameter that we are measuring. we are trying to measure the center position of this hole....
05-29-2020, 08:45 AM -
by CaemgenOk, I have to check a part as shown in the pic.
The start of the hole is at the arrowhead with a position of .014 applied to it.
02-24-2014, 01:51 PM -
by AlexAI want to be able to load a part on a fixture either way up, and the program select the correct cycle based on whether a hole is or isn't present....
05-24-2012, 05:11 AM -
