I have an 8" shaft on the machine long ways in the Y axis. I measure a Ø 3.00" X 2" deep cylinder on one side (Y+) and a Ø 4.00 X 2" deep cylinder on the opposite side (Y-). Is it possible to create 1 cylinder (centerline) out of the 2 cylinders? I've used all possible configurations (Auto, Best Fit, BF ReComp, Projection, Cast and Reverse) and it keeps telling me there is not enough features. Is there a way possible to create this?
These 2 cylinders create a datum (Datum -A- & Datum -C- or A-C as called out on the drawing) and there is a Total Run Out called out from a different diameter on the shaft back to the A-C datum.
