My probe setup is a PH6 Renishaw with one vertical and one horizontal tips on a Sheffield CMM with version 3.7.
The problem is that I noticed a big variance in my Y measurements using the horizontal probe. I calibrated both tips multiple times and the vertical tip was consistant. The horizontal tip varied in the Y .045. Yes I checked to see if the tip was tight. I see the data change in the edit probe window in the Y .
