Running the same program on 2 different machines
  • Running the same program on 2 different machines
    We are having problems running the exact same program on 2 machines. The machines are both Global 555. They are setup exactly the same.
    Same fixturing, same probe setup, same probe names. All probe calibrations are stored local for both machines. When we run the program on the original machine
    everything looks fine. We copied the program and .cad files to our other machine and the first scan it does errors out.. We get a Find Nominals Tolerance box asking if we want to change the Find
    Nominals for this scan. I have increased the tolerance and no luck. Also... in the pic, you can see as it scans the chamfer on the part it, it shows these 2 blips in the scan.
    We are using PCDmis 2019 R1 SP4 with a LSPX1C and a star stylus setup.
    X_SECTION_1=FEAT/SCAN,FREEFORM,NUMBER OF HITS=578,SHOW HITS=NO,SHOWALLPARAMS=YES
    EXEC MODE=DEFINED, NOMS MODE=FIND NOMS,CLEARPLANE=NO,SINGLE POINT=NO,THICKNESS=0
    FINDNOMS=0.05,SELECTEDONLY=NO,USEBESTFIT=NO,PROBEC OMP=YES,AVOIDANCE MOVE=NO,DISTANCE=20,CAD Compensation=YES,4-axis scan=NO
    DIR1=FREEFORM,
    HITTYPE=VECTOR
    INITVEC=0,1,0
    DIRVEC=0,0,0
    POINT1=0,0.891,0.7566
    MEAS/SCAN
    BASICSCAN/FREEFORM,NUMBER OF HITS=578,SHOW HITS=NO,SHOWALLPARAMS=YES
    <0,0.891,0.7566>,<0,0.0468,-0.616>,DirVec=0,0,-1
    InitVec=0,1,0,THICKNESS=0
    FILTER/NULLFILTER,
    EXEC MODE=DEFINED
    BOUNDARY/
    HITTYPE/VECTOR
    NOMS MODE=FINDNOMS,0.05
    ENDSCAN
    ENDMEAS/
    Thanks for any help..
    PCDMIS 2019 R1
    GLOBAL 5x5
    What size probe are you using? You have a find noms tolerance of .05. Im assuming this is not metric so any probe bigger than .05in you would have issues. Rule of thumb, find noms tolerance should be the probe radius, plus feature tolerance, plus at least 10% for added variation. I use probe diameter as the tolerance, unless I need more, and I havent had issues. Also, there could be a possibility that the Find Noms prompt that pops up after the scan executes could have been set to "dont show this message again" on the original machine but not the new one. You can check this under F5 and warnings. You can also double check the scan to verify the surfaces are properly selected.
      Singularity... I am using 2mm stylus and my findnoms is in inches. I increased the findnoms up to .100in and still had the same problems. I am getting the Find Noms prompt after the scan.
      I double checked to verify the proper surfaces were selected. All looks good.
      Thanks for the reply... I will keep plugging away..
      PCDMIS 2019 R1
      GLOBAL 5x5
        X_SECTION_1=FEAT/SCAN,FREEFORM,NUMBER OF HITS=578,SHOW HITS=NO,SHOWALLPARAMS=YES EXEC
        FINDNOMS=0.05,SELECTEDONLY=NO,USEBESTFIT=[COLOR=#e74c3c]YES[/COLOR],PROBEC OMP=YES,AVOIDANCE MOVE=NO,DISTANCE=20,CAD
        Compensation=[COLOR=#e74c3c]NO[/COLOR],4-axis scan=NO DIR1=FREEFORM
        Changes I would make, unfortunately you would have to recreate the scan. CAD Comp will look at the points as 3D, kinda looks like a 2D scan, but I don't know the whole story.
        • Marken199
          Marken199 commented
          Yes. It is a 2D scan. I will try that tomorrow and see what happens. Thanks.
        No skan king here, but is this in the program?
        OPTIONPROBE/MAXFORCE=0.36,LOWFORCE=0.06,UPPERFORCE=0.18,TRIGGE RFORCE=0.06,
        PROBEACCURACY=0.1,POSACCURACY=0.1,#RETURNDATA=7,
        RETURNSPEED=1,SCANPNTDENSITY=4,
        SCANACCELERATION=10,SCANOFFSETFORCE=0.12,
        PROBINGMODE=DFL,MANFINEPROBING=NO
        (settings per your LSPX1C ) Optprobe nonsense should be in your program, no?
        • Jeeper
          Scan jumps around corners
          by Jeeper
          G'day folks,
          I am having an issue with linear open scanning. As you can see on the screenshot, the probe does not follow the profile around...
          07-07-2019, 04:53 PM
        • NMC_CMM
          Continuous Scan with FindNoms
          by NMC_CMM
          I'm trying to do a continuous scan of a profile (V4.3) with FindNoms turned on. My question/problem is with the tolerance. If I set the tolerance to...
          07-01-2008, 09:53 AM
        • Hirxm
          Scan Segment Issues
          by Hirxm
          So I have this round part and the program we have uses several scan segments to create a circle. The problem is that sometimes the scan appears on the...
          03-31-2020, 03:48 PM
        • Jeff Hunt
          Scan in a DCC program
          by Jeff Hunt
          I have what is probobly a simple question. I am using PCDMIS 2010 & I have a program where I have written in section scans throught some areas of...
          07-09-2010, 09:15 AM
        • PDARR
          Scan Issues
          by PDARR
          Well I changed a TTP scan to an analog scan and I get a window that tells me "cannot find nominals for some hits." I have changed the find nominal...
          04-23-2014, 09:11 AM
