We just updated our system with new hard drives with PCDMIS 2020 R1 - I can't get any of our Disk probes to calibrate properly. I have never had this issue before. I was able to go in and repick up the tool holder and calibration all our other probes, except for these. Anyone else experience this issue???
PCDMIS 2020 R1 Disk Probe Calibration
I just checked my disk and they are calibrating just fine using PCD 2020 R1. Did you get all your prob files to move over?2024 can't get here soon enough!!!
Probe profiles moved over without a hitch, picked up the tool holders on both machines - no problems. Calibration of all the other probes no problem, it just can't figure out where the disk probe is or what size. So I am moving X Y Z coordinates around .010 at a time. I have gotten closer, but still no sucess.
Have you contacted Hexagon? Checking the probe build looks OK. I believe this is above my pay scale.
by bpenningsDoes anyone have a documented procedure for calibrating disk probes? The PCDMIS procedure does not work for me for some reason. It is 18mm in dia. and...
04-22-2008, 05:22 PM -
by programmerI am PCDMIS 4.3 and having problem trying to calibrate a disk probe. any help???
08-04-2009, 12:10 PM -
Does anybody know how to calibrate a disk in PCDMIS 2010 MR2.
Im getting out of calibration disk by 2 mm or so, because when I send to calibrate...-
11-09-2010, 02:22 PM -
by HirxmOk so this is the second time I ask how to calibrate a disk probe. The thing is that PC-DMIS doesn't let me calibrate a disk probe as it should. This...
08-30-2019, 11:09 AM -
Hello all!
I am using PC DMIS 3.7 MR2 with SP25. I would like to calibrate a disk probe D45 and 1.5 mm thickness.
Seems...-
01-15-2007, 08:20 AM -
