Hi all,
so i have the same exact program on two different machines, using the same probe tips, same angles, identical fixtures, basically everything is the same. I have IF/GOTO statements that pull up the machine and station of where the part was made. One machine is telling me the correct info, the other one doesn't. I am so confused. I deleted the program on the machine that doesn't give me the correct info and copied the program from the other machine to this one, still the same problem. I am lost. They are just IF commands. The parts have a little step to identify the machine and station. So the commands just say If there is a step in this particular spot then it's Mach#1, station#1,etc. This machine will go through all the steps and then on the report it always says Station2 no matter what station it is.
Has anyone had this problem before?
Using PCDMIS 2019 R1
