when measuring concentricity I have a part that is large and is cone shaped ( like a road cone). i measure the diameter on top and then drop down to a diameter at the middle bottom and get the following.
(top diameter)
X -0.0001
Y -0.0001
D 15.9433
RN 0.0001
(middle bottom diameter)
X -0.0004
Y 0.0001
D 22.0128
RN 0.0001
however, when checking the concenticity between the two i get it out 0.0025
how can i be almost spot on in X & Y but be out that much in concenticity?
this is a very large part about 36.5" in over all length.
we put the part on the table level, level the top of the part and check to top OD then the bottom OD and construct a centerline then inspect the above mentioned areas and check concentricity between the two.Doc1.docx
(top diameter)
X -0.0001
Y -0.0001
D 15.9433
RN 0.0001
X -0.0004
Y 0.0001
D 22.0128
RN 0.0001
