Reporting profile of a radius is not working after size change
  • Reporting profile of a radius is not working after size change
    Hello. We have a part that used to have two 0.218" +/-0.005" radii, but our customer changed the size of the radii to 0.210" +/-0.005". We want to report profile of the radii and analysis, so we can see if tooling is not cutting well. I changed the theoretical size of the auto feature circles to 0.420" (double the radius), and then I make constructed feature sets for those circles. I reported profile (form and location) 0" +/-0.005", radius size 0.210" +/-0.005", and analysis of the constructed feature sets. We make this part in a mill, so we changed the mill to cut 0.210" radii, and I checked the part. I get a profile measurement of 0.0062" and a radius size measurement of 0.2129". I have a Solidworks CAD model in this program, but is there any way I can change something in PC-DMIS to get the profile to show correctly? Or do I need to edit the Solidworks model?
    We need a bit more info to give you a good answer to your question. Did the center point change location and the only change is the radius size? Or did the size change AND the centerpoint location change? How are you measuring the radius? AutoCircle? Measured Circle? Autopoints and constructed circle? If you programmed off of a model doesn't exactly match the print, then you will definitely have to change the model out for the correct one.
    • Darrin@AI
      [email protected] commented
      The center point did NOT change. The only change is the radius SIZE. First I measured the radii with AutoCircles, and then I made Constructed Feature Sets from the AutoCircles to display the analysis. So if I have a model in the program, I have to change the model to fix my profile problem?
    • Mike Ruff
      Mike Ruff commented
      If the centerpoint is in the exact same location and only the radius changed, then changing the radius size will be sufficient. You might need to update the nominals of the Constructed Feature Set and associated dimensions, though. Every time you update a feature, you need to update everything that is dependent on that feature as well.
      You don't NEED to import the new model as long as ALL of your nominals are CORRECT PER PRINT. However, if it were me, I would definitely update the model so the print and model match. I would never recommend having a print and model that don't match; but if that's the route you need to go for whatever reason, I would recommend putting in some $$ comments to describe why you aren't programmed to the model.
    • Darrin@AI
      Thank you Mike. I will update the Constructed feature sets, too, and I will ask someone here to update the model.
    Make sure you don't have the nominals mode set to "FIND NOMS" in the auto-features. You need to set it to NOMINALS in this case, otherwise it will look at the CAD model rather than the typed in values.
    Neil Challinor
    PC-DMIS Product Owner
    E: [email protected]
    • Darrin@AI
      Thank you Neil, but I lucked-out. The auto features were and are set to "Nominals."
    [email protected] , this is a bit of a long shot but check your warnings (under F5) - specifically the one for update nominals of associated dimensions. When you edited the radius of your auto-circles, PC-Dmis should have asked if you also wanted to update the nominals of the associated dimensions. If you selected NO then the feature would have the new size but the dimension would still be using the old nominal. Similarly, if someone had previously answered NO to that prompt and ticked "don't ask me again", the nominal in the dimension would not update.
    Neil Challinor
      How do I restore the warnings, someone cleared the list and now it is grayed out, I want to add the warnings back.
        F5. Warnings. Then uncheck the box
        7107 Global Classic TP20
        2019R1 SP1 CAD++
          i have cleared the warnings and it still in not asking me do you want to update nominals
            Your center point would have to change, because if you share the same center point as the bigger radius. Then you would end up with a step on each side of the radius because it is smaller. move your center value whether it be X,Y or Y and Z or X and Z to move starting from 0. originally move .218 in both directions to .210 to create your new center point, unless of course there is suppose to be a step as shown then you will need to make your hit Radius smaller so it is not to hit the steps.
              whoops this an old thread that was invaded by a gremlin, sorry just realized the dates and subject was changed.
