How to look at certain dims only?
  • How to look at certain dims only?
    Hi all,
    so i have a part with 200+ features on it, and they changed all the angle tolerances to +-.5degrees. Is there anyway that i could just show my angle dimensions on the program so i can change them instead of going through every dimension one by one? Like if i want to see 2d distances only then see those only,etc
    You could use the search function (ALT+F3) to search for 2D ANGLE or 3D ANGLE. This will allow you to step through your program and edit each call out. You could do the same thing with a script to automate the process which would probably be a lot quicker if you have lots of programs to edit.
    This should work for all 3D or 2D angle dimensions. When you run it, it will aske you to enter a +TOL and then a -TOL before replacing all the tolerances in all existing 2D or 3D angle dimensions.
    Dim DmisApp As Object
    Dim DmisPart As Object
    Dim DmisCommands As Object
    Dim DmisCommand As Object
    Sub Main
    Set DmisApp = CreateObject("PCDLRN.Application")
    Set DmisPart = DmisApp.ActivePartProgram
    Set DmisCommands = DmisPart.Commands
    CommandCount = DmisCommands.Count
    Set DmisCommand = DmisCommands.Item(CommandCount)
    DmisCommands.InsertionPointAfter DmisCommand
    myTitle$ = " "
    Prompt$ = "Enter the +TOL value"
    Default$ = ""
    X% = 200
    T% = 200
    PTOL$ = InputBox$(Prompt$,myTitle$,Default$,X%,Y%)
    myTitle$ = " "
    Prompt$ = "Enter the -TOL value"
    Default$ = ""
    X% = 200
    T% = 200
    MTOL$ = InputBox$(Prompt$,myTitle$,Default$,X%,Y%)
    For Each DmisCommand In DmisCommands
    If DmisCommand.Type = 1108 Or DmisCommand.Type = 1109 Then
    ' Set Plus Tolerance = PTOL$
    retval = DmisCommand.PutText (PTOL$, 167, 0)
    ' Set Minus Tolerance = MTOL$
    retval = DmisCommand.PutText (MTOL$, 168, 0)
    DmisCommand.ReDraw
    End If
    Next
    DmisPart.RefreshPart
    End Sub
    Neil Challinor
    PC-DMIS Product Owner
    E: [email protected]
      Sub Main
      myTitle$ = " "
      Default$ = ""
      X% = 200
      T% = 200
      myTitle$ = " "
      Default$ = ""
      X% = 200
      T% = 200
      DmisCommand.ReDraw
      End If
      Next
      End Sub
      AWESOME! Thank you so much
