how to make the probe visible
  • how to make the probe visible
    hello every one
    i am trying to make the probe visibe on the offline programing mode.can some guide me in the right direction
    In the tool bar click the probe icon.
    Darroll
    2018R2
      Put the cursor on the first Tip command after the Loadprobe command line and hit Enter for a new line.
      Type "LOADM" and LOADMACHINE should appear, then hit tab.
      The line should then read "LOADMACHINE/No Machine"
      This will show the probe head at all times.
      PC-DMIS 2016.0 SP8
      Jeff
        Press Ctrl-Alt-P to open the probe utilities window. Look at the bottom box on the left "the build area" next to any item if it says "NoDraw" it will not show in the CAD window. To see them double click on the item and check the box for "draw this component". This is a global change for the probe you are editing.
