Alignment Question
  • Alignment Question
    Can anyone explain how to align this part to A-D B C. See print attached. PCDMIS Help Image.JPG
    I'm assuming the D target areas aren't coplanar to A, still no problem. You need to create an offset plane for A-D, that will be the primary, a line through the axis indicated for both B slots. Between those two features , if A-D were facing up, you'd have the level, Z origin, X axis (B), Y origin, so you'd use C as the X origin (they actually show that the way the leaders are drawn).
      Thanks RandomJerk, Can you elaborate on the offset plane A-D. How can that be accomplished?
        Creating a offset plane
        Constructed plane > drop down "offset plane" > click offsets > calculate offsets > set your vector > Calculate > ok > create
        Please Join The Effort.
        https://www.pcdmisforum.com/forum/pc...o-metric/page2 (Comment #17)
          My eyes are awful and I cant read whats on the print. However I do have a GD&T question on this same subject. When in a FCF and it calles out something like POS|Ø.2|A-B|C, this is asking that you take the position of the hole or slot or whatever back to A and B simultaneously and not individually, correct? My GD&T is not the greatest and I have been working on it for about 6 months now, some of the stuff is just super hard for me wrap my head around
          Thanks in advance.
            Without being able to see and read the entire print.... and knowing certain OEM 'designers' the way I do (and what I have to deal with)....
            There should be a fixture for this. Nets & clamps and Pins and so forth.
            Align the fixture. Load the part on the "B" and "C" (4-way & 2-way) and clamp all the "A" nets. There should be (and it is forgotten 90+% of the time) a callout for a free-state check for the "D". Once you check the "D" datum to A-B-C, clamp D and check the rest of the part.
              Matt Hoedeman, you are exactly correct. There is a free state check to D and two clamps to lock on that surface.
