I'm writing a program using auto-features and picking on the CAD for my nominal. My CAD doesn't have material thickness, so I'm using the T-value surface option to compensate for it. Attached is what I'm seeing. the previous 30+ edge points were plotting just fine, but now I've gotten on the other edge of the part, it isn't wanting to do right. Picture of hits and full code below. Any suggestions on what the issue could be would be greatly appreciated.
Edge point/Cad issue
PART NAME : 76304-6TA0A
REV NUMBER : 4258
SER NUMBER :
STATS COUNT : 1
ALIGNMENT/END
MODE/MANUAL
MOVESPEED/ 200
TOUCHSPEED/ 5
FLY/ON
TEMPCOMP/METHOD = AUTOMATIC,MATERIAL = Zerodur; Nexcera,CTE=0
,SET WARNING LIMIT = TRUE,MINIMUM = 18,MAXIMUM = 22
,PART SENSOR NUM=DEFAULT,X SCALE= 20,Y SCALE= 20,Z SCALE= 20,PART TEMP=20
LOADPROBE/100_TP20_SF_30X2
MOVE/POINT,NORMAL,<2312.104,455.842,1297.209>
MOVE/POINT,NORMAL,<691.754,387.809,710.479>
CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<575,773.251,735>,<0,-1,0>,6
ACTL/<-2758.977,1598.307,-1225.207>,<0.0000337,-0.9999937,0.0035518>,6.006
TARG/<575,773.251,735>,<0,-1,0>
START ANG=0,END ANG=360
ANGLE VEC=<1,0,0>
DIRECTION=CCW
SHOW FEATURE PARAMETERS=NO
SHOW CONTACT PARAMETERS=YES
NUMHITS=4,DEPTH=2,PITCH=0
SAMPLE METHOD=SAMPLE_HITS
SAMPLE HITS=3,SPACER=0.5
AVOIDANCE MOVE=BOTH,DISTANCE=5
SHOW HITS=NO
MOVE/POINT,NORMAL,<573.628,695.649,731.056>
PNT1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<823.041,745.511,956.636>,<0.0134362,-0.9730227,-0.2303179>
ACTL/<-2510.786,1570.577,-1003.74>,<0.0133966,-0.9729765,-0.2305151>
TARG/<823.041,745.511,956.636>,<0.0134362,-0.9730227,-0.2303179>
SHOW HITS=NO
MOVE/POINT,NORMAL,<799.41,698.932,979.32>
PNT2 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<783.466,747.499,1032.292>,<-0.2390797,-0.9685663,0.0687041>
ACTL/<-2550.311,1572.545,-928.058>,<-0.2389215,-0.9686074,0.0686751>
TARG/<783.466,747.499,1032.292>,<-0.2390797,-0.9685663,0.0687041>
SHOW HITS=NO
MOVE/POINT,NORMAL,<789.006,520.222,1030.987>
MOVE/POINT,NORMAL,<2013.051,521.559,1214.088>
PNT3 =FEAT/CONTACT/VECTOR POINT/DEFAULT,CARTESIAN
THEO/<2190.138,636.521,1263.689>,<-0.0106074,-0.893023,-0.449886>
ACTL/<-1143.473,1461.686,-697.615>,<-0.0108019,-0.8929372,-0.4500517>
TARG/<2190.138,636.521,1263.689>,<-0.0106074,-0.893023,-0.449886>
SHOW HITS=NO
MOVE/POINT,NORMAL,<2192.164,574.695,1269.24>
CIR2 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<2313,612,1296.5>,<0,-1,0>,6
ACTL/<-1020.771,1439.97,-664.889>,<-0.0037154,-0.9999922,0.0013604>,6.007
TARG/<2313,612,1296.5>,<0,-1,0>
ANGLE VEC=<0,0,-1>
DIRECTION=CCW
SHOW HITS=NO
ALIGNMENT/ITERATE
PNT TARGET RAD=5,START LABEL=,FIXTURE TOL=0.05,ERROR LABEL=
MEAS ALL FEAT=ALWAYS,MAX ITERATIONS=99,LEVEL AXIS=YAXIS,ROTATE AXIS=ZAXIS,ORIGIN AXIS=XAXIS
LEVEL=PNT1,PNT2,PNT3,,
ROTATE=CIR1,CIR2,,
ORIGIN=CIR1,,
ALIGNMENT/END
Going DCC Mode. Clear probe and load part.
MODE/DCC
MOVE/POINT,NORMAL,<2555.81,254.026,1254.856>
TIP/T1A15B-67.5, SHANKIJK=0.099, -0.966, -0.239, ANGLE=0.007
TRIM47 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2457.694,639.93,1244.41>,<0.0043586,0.4426861,-0.896666>,<-0.0184839,-0.8964857,-0.4426869>
ACTL/<2457.713,640.482,1245.46>,<-0.0283579,0.4513711,-0.8918856>,<-0.0095317,-0.892326,-0.4512909>
TARG/<2457.694,639.93,1244.41>,<0.0043586,0.4426861,-0.896666>,<-0.0184839,-0.8964857,-0.4426869>
MEASURE ORDER=SURFACE
DEPTH=0.3
SAMPLE HITS=5,SPACER=3,INDENT1=2
ONERROR=NO
SHOW HITS=NO
TRIM48 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2435.361,639.244,1248.188>,<-0.4289627,0.4079065,-0.8059797>,<-0.0178462,-0.8958921,-0.4439131>
ACTL/<2435.622,639.657,1249.001>,<-0.4706603,0.4024437,-0.7851866>,<-0.0074077,-0.8916879,-0.4525901>
TARG/<2435.361,639.244,1248.188>,<-0.4289627,0.4079065,-0.8059797>,<-0.0178462,-0.8958921,-0.4439131>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM49 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2412.453,635.897,1254.477>,<-0.1730689,0.4433652,-0.879474>,<-0.0171666,-0.8941711,-0.4473963>
ACTL/<2412.588,635.915,1255.281>,<-0.1738441,0.4328985,-0.8845208>,<-0.0073787,-0.8987449,-0.4384097>
TARG/<2412.453,635.897,1254.477>,<-0.1730689,0.4433652,-0.879474>,<-0.0171666,-0.8941711,-0.4473963>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM50 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2393.247,635.902,1256.536>,<-0.0436613,0.4482962,-0.8928181>,<-0.0165919,-0.8938725,-0.4480142>
ACTL/<2393.28,635.988,1257.19>,<-0.0408738,0.4555248,-0.8892843>,<-0.0178773,-0.890219,-0.4551819>
TARG/<2393.247,635.902,1256.536>,<-0.0436613,0.4482962,-0.8928181>,<-0.0165919,-0.8938725,-0.4480142>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM51 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2356.529,634.532,1257.908>,<-0.0200847,0.4489594,-0.8933264>,<-0.01551,-0.893539,-0.4487176>
ACTL/<2356.533,634.524,1258.559>,<-0.0351664,0.4571422,-0.8886981>,<-0.008712,-0.8893546,-0.4571351>
TARG/<2356.529,634.532,1257.908>,<-0.0200847,0.4489594,-0.8933264>,<-0.01551,-0.893539,-0.4487176>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM52 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2300.189,635.939,1258.732>,<-0.0185033,0.4492848,-0.8931969>,<-0.0138505,-0.8933793,-0.4490897>
ACTL/<2300.207,635.694,1259.403>,<-0.0192486,0.4806932,-0.8766776>,<-0.0139987,-0.8768837,-0.4804988>
TARG/<2300.189,635.939,1258.732>,<-0.0185033,0.4492848,-0.8931969>,<-0.0138505,-0.8933793,-0.4490897>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM53 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2220.807,636.218,1260.412>,<-0.0161589,0.4494188,-0.893175>,<-0.0115115,-0.893316,-0.4492816>
ACTL/<2220.817,636.305,1260.835>,<-0.0152582,0.5107889,-0.8595707>,<-0.0102933,-0.8597055,-0.5106863>
TARG/<2220.807,636.218,1260.412>,<-0.0161589,0.4494188,-0.893175>,<-0.0115115,-0.893316,-0.4492816>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
MOVE/POINT,NORMAL,<2225.94,610.917,1217.64>
MOVE/POINT,NORMAL,<2225.926,493.038,1217.662>
MOVE/POINT,NORMAL,<2095.472,493.054,1217.575>
TRIM54 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2107.96,636.513,1262.309>,<-0.0109965,0.4498176,-0.8930527>,<-0.0081872,-0.8931173,-0.4497494>
ACTL/<2107.959,636.138,1262.426>,<-0.0072366,0.4794442,-0.8775425>,<-0.0114752,-0.8775475,-0.4793523>
TARG/<2107.96,636.513,1262.309>,<-0.0109965,0.4498176,-0.8930527>,<-0.0081872,-0.8931173,-0.4497494>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM55 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<2004.077,636.762,1263.35>,<-0.0046247,0.4505782,-0.892725>,<-0.0051275,-0.8927335,-0.4505559>
ACTL/<2004.098,636.585,1263.543>,<0.0969583,0.459768,-0.8827301>,<-0.0067284,-0.8865858,-0.4625152>
TARG/<2004.077,636.762,1263.35>,<-0.0046247,0.4505782,-0.892725>,<-0.0051275,-0.8927335,-0.4505559>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM56 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<1908.334,637.062,1263.547>,<0.004142,0.4503881,-0.8928233>,<-0.0023063,-0.8928242,-0.4503993>
ACTL/<1908.332,636.811,1264.087>,<0.0048186,0.4629204 ,-0.8863867>,<0.0007842,-0.8863985,-0.4629223>
TARG/<1908.334,637.062,1263.547>,<0.004142,0.4503881,-0.8928233>,<-0.0023063,-0.8928242,-0.4503993>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
TRIM57 =FEAT/CONTACT/EDGE POINT/DEFAULT,CARTESIAN
THEO/<1860.462,636.205,1262.752>,<0.0096248,0.4503706 ,-0.8927898>,<-0.0008957,-0.8928269,-0.450399>
ACTL/<1860.459,635.738,1263.073>,<0.0089306,0.4446564 ,-0.8956567>,<0.0002479,-0.8956934,-0.4446722>
TARG/<1860.462,636.205,1262.752>,<0.0096248,0.4503706 ,-0.8927898>,<-0.0008957,-0.8928269,-0.450399>
DEPTH=0.3
ONERROR=NO
SHOW HITS=NO
Trim58 =feat/contact/edge point/default,cartesian
theo/<1834.183,641.394,1255.093>,<0.1048869,0.4433831 ,-0.8901742>,<-0.0001157,-0.8951061,-0.4458532>
actl/<1834.145,640.857,1255.392>,<0.149785,0.4184847,-0.8957874>,<0.0036024,-0.9062334,-0.4227624>
targ/<1834.183,641.394,1255.093>,<0.1048869,0.4433831 ,-0.8901742>,<-0.0001157,-0.8951061,-0.4458532>
measure order=surface
show feature parameters=no
show contact parameters=yes
depth=0.3
sample hits=5,spacer=1.5,indent1=2
avoidance move=both,distance=5
onerror=no
show hits=no
trim59 =feat/contact/edge point/default,cartesian
theo/<1802.947,637.9,1259.381>,<0.0175398,0.448439,-0.8936413>,<0.0008005,-0.8937848,-0.4484953>
actl/<1802.91,637.531,1259.585>,<-0.0783317,0.4294496,-0.8996873>,<-0.0001188,-0.9024642,-0.4307648>
targ/<1802.947,637.9,1259.381>,<0.0175398,0.448439,-0.8936413>,<0.0008005,-0.8937848,-0.4484953>
depth=0.3
sample hits=5,spacer=3,indent1=2
onerror=no
show hits=no
trim60 =feat/contact/edge point/default,cartesian
theo/<1707.635,637.474,1259.761>,<0.0353056,0.448393,-0.893139>,<0.0036088,-0.8937475,-0.4485559>
actl/<1707.635,637.474,1259.761>,<0.0353056,0.4483931 ,-0.8931389>,<0.0036088,-0.8937475,-0.4485559>
targ/<1707.635,637.474,1259.761>,<0.0353056,0.448393,-0.893139>,<0.0036088,-0.8937475,-0.4485559>
depth=0.3
onerror=no
show hits=no
trim61 =feat/contact/edge point/default,cartesian
theo/<1632.705,642.586,1251.399>,<-0.1218026,0.4406693,-0.8893676>,<0.0058108,-0.8957072,-0.4446063>
actl/<1632.743,642.603,1251.781>,<-0.115448,0.4560085,-0.8824557>,<0.0020802,-0.888283,-0.4592919>
targ/<1632.705,642.586,1251.399>,<-0.1218026,0.4406693,-0.8893676>,<0.0058108,-0.8957072,-0.4446063>
depth=0.3
onerror=no
show hits=no
trim62 =feat/contact/edge point/default,cartesian
theo/<1596.562,639.433,1254.536>,<0.0669563,0.4457669 ,-0.8926414>,<0.0068852,-0.8948342,-0.4463455>
actl/<1596.55,639.407,1254.679>,<0.0729903,0.4701495,-0.8795634>,<0.0112242,-0.8822472,-0.4706526>
targ/<1596.562,639.433,1254.536>,<0.0669563,0.4457669 ,-0.8926414>,<0.0068852,-0.8948342,-0.4463455>
depth=0.3
onerror=no
show hits=no
trim63 =feat/contact/edge point/default,cartesian
theo/<1533.025,642.307,1250.325>,<0.0926951,0.4429904 ,-0.8917214>,<0.0087602,-0.8959055,-0.4441583>
actl/<1533.05,642.057,1249.996>,<0.097316,0.4765484,-0.8737455>,<0.025266,-0.8788125,-0.4764979>
targ/<1533.025,642.307,1250.325>,<0.0926951,0.4429904 ,-0.8917214>,<0.0087602,-0.8959055,-0.4441583>
depth=0.3
onerror=no
show hits=no
trim64 =feat/contact/edge point/default,cartesian
theo/<1465.181,643.954,1242.765>,<0.12938,0.4381545,-0.88954>,<0.010762,-0.8976475,-0.4405827>
actl/<1465.262,643.231,1241.898>,<0.1432041,0.4417074 ,-0.8856563>,<0.0193713,-0.8959593,-0.4437136>
targ/<1465.181,643.954,1242.765>,<0.12938,0.4381545,-0.88954>,<0.010762,-0.8976475,-0.4405827>
depth=0.3
onerror=no
show hits=no
trim65 =feat/contact/edge point/default,cartesian
theo/<1411.433,648.449,1234.86>,<0.1694003,0.4322816,-0.885684>,<0.0123511,-0.8995328,-0.4366785>
actl/<1411.552,647.51,1233.75>,<0.1634305,0.4289053,-0.8884428>,<0.0127494,-0.9013939,-0.4328123>
targ/<1411.433,648.449,1234.86>,<0.1694003,0.4322816,-0.885684>,<0.0123511,-0.8995328,-0.4366785>
depth=0.3
onerror=no
show hits=no
trim66 =feat/contact/edge point/default,cartesian
theo/<1347.795,651.805,1223.162>,<0.2341598,0.4226337 ,-0.8755284>,<0.0142373,-0.90196,-0.4315849>
actl/<1347.951,650.826,1222.011>,<0.2353768,0.4185831 ,-0.8771465>,<0.004905,-0.9030032,-0.4296059>
targ/<1347.795,651.805,1223.162>,<0.2341598,0.4226337 ,-0.8755284>,<0.0142373,-0.90196,-0.4315849>
depth=0.3
onerror=no
show hits=no
trim67 =feat/contact/edge point/default,cartesian
theo/<1293.001,658.863,1209.577>,<0.3043099,0.4085585 ,-0.8605088>,<0.0158504,-0.9053987,-0.4242663>
actl/<1292.837,657.687,1209.654>,<0.3103676,0.3791408 ,-0.8717363>,<0.0073358,-0.9179499,-0.3966285>
targ/<1293.001,658.863,1209.577>,<0.3043099,0.4085585 ,-0.8605088>,<0.0158504,-0.9053987,-0.4242663>
depth=0.3
onerror=no
show hits=no
trim68 =feat/contact/edge point/default,cartesian
theo/<1209.137,671.003,1179.657>,<0.4097038,0.3814694 ,-0.8286277>,<0.0183568,-0.9116291,-0.4106038>
actl/<1209.028,670.119,1179.538>,<0.4114473,0.3437507 ,-0.8441247>,<-0.0080215,-0.924749,-0.380493>
targ/<1209.137,671.003,1179.657>,<0.4097038,0.3814694 ,-0.8286277>,<0.0183568,-0.9116291,-0.4106038>
depth=0.3
onerror=no
show hits=no
trim69 =feat/contact/edge point/default,cartesian
theo/<1109.645,689.48,1132.126>,<0.4907223,0.3471735,-0.7991634>,<0.0213012,-0.9216972,-0.3873248>
actl/<1109.655,688.786,1131.849>,<0.4961327,0.3268505 ,-0.8043762>,<0.0117152,-0.9288731,-0.3702128>
targ/<1109.645,689.48,1132.126>,<0.4907223,0.3471735,-0.7991634>,<0.0213012,-0.9216972,-0.3873248>
depth=0.3
onerror=no
show hits=no
trim70 =feat/contact/edge point/default,cartesian
theo/<1006.897,710.23,1074.155>,<0.5331642,0.3162654,-0.7846733>,<0.0243573,-0.9328508,-0.3594387>
actl/<1006.971,709.793,1073.876>,<0.5342786,0.289247,-0.7942812>,<0.0050752,-0.9407154,-0.3391589>
targ/<1006.897,710.23,1074.155>,<0.5331642,0.3162654,-0.7846733>,<0.0243573,-0.9328508,-0.3594387>
depth=0.3
onerror=no
show hits=no
trim71 =feat/contact/edge point/default,cartesian
theo/<924.257,726.857,1022.964>,<0.5566358,0.2908502,-0.7781791>,<0.0267977,-0.9425101,-0.3331016>
actl/<924.364,727.23,1022.913>,<0.5567588,0.2978566,-0.775436>,<0.0305553,-0.9402137,-0.3392117>
targ/<924.257,726.857,1022.964>,<0.5566358,0.2908502,-0.7781791>,<0.0267977,-0.9425101,-0.3331016>
depth=0.3
onerror=no
show hits=no
move/point,normal,<926.845,573.93,1018.204>
move/point,normal,<793.002,573.918,875.896>
trim72 =feat/contact/edge point/default,cartesian
theo/<796.595,748.996,934.026>,<0.6266718,0.1646963,-0.7616808>,<0.0078316,-0.9786936,-0.205177>
actl/<796.932,748.821,933.566>,<0.6291684,0.1646191,-0.7596365>,<0.0122563,-0.9792945,-0.2020694>
targ/<796.595,748.996,934.026>,<0.6266718,0.1646963,-0.7616808>,<0.0078316,-0.9786936,-0.205177>
depth=0.3
onerror=no
show hits=no
trim73 =feat/contact/edge point/default,cartesian
theo/<724.978,758.941,870.551>,<0.7098057,0.1151011,-0.6949299>,<0.0005994,-0.9866576,-0.1628077>
actl/<725.296,758.492,870.156>,<0.7109862,0.0917553,-0.697194>,<-0.013764,-0.989445,-0.1442537>
targ/<724.978,758.941,870.551>,<0.7098057,0.1151011,-0.6949299>,<0.0005994,-0.9866576,-0.1628077>
depth=0.3
onerror=no
show hits=no
trim74 =feat/contact/edge point/default,cartesian
theo/<684.111,767.937,821.001>,<0.8705178,0.0736044,-0.4866016>,<0.0006212,-0.9889161,-0.1484743>
actl/<684.436,767.286,820.726>,<0.8724659,0.0722389,-0.4833062>,<0.0052406,-0.9903396,-0.138564>
targ/<684.111,767.937,821.001>,<0.8705178,0.0736044,-0.4866016>,<0.0006212,-0.9889161,-0.1484743>
depth=0.3
onerror=no
show hits=no
Trim75 =feat/contact/edge point/default,cartesian
theo/<663.622,779.284,726.076>,<0.9977876,0.0058022,-0.0662288>,<0,-0.9961843,-0.0872745>
actl/<663.726,778.595,726.002>,<0.9975223,0.0126198,-0.0692101>,<0.0058653,-0.9952727,-0.0969422>
targ/<663.622,779.284,726.076>,<0.9977876,0.0058022,-0.0662288>,<0,-0.9961843,-0.0872745>
depth=0.3
onerror=no
show hits=no
trim76 =feat/contact/edge point/default,cartesian
theo/<660.149,783.343,691.023>,<0.9904784,0.0087968,-0.1373866>,<0,-0.9979564,-0.063899>
actl/<660.131,782.458,690.979>,<0.9899006,0.0105739,-0.141368>,<0.0032442,-0.9986429,-0.0519784>
targ/<660.149,783.343,691.023>,<0.9904784,0.0087968,-0.1373866>,<0,-0.9979564,-0.063899>
depth=0.3
onerror=no
show hits=no
move/point,normal,<664.328,768.541,690.163>
trim77 =feat/contact/edge point/default,cartesian
theo/<591.87,773.9,679.8>,<0,0,-1>,<0,-1,0>
actl/<591.886,772.697,679.8>,<-0.0002208,-0.008423,-0.9999645>,<0.0127786,-0.9998829,0.0084195>
targ/<591.87,773.9,679.8>,<0,0,-1>,<0,-1,0>
depth=0.3
onerror=no
show hits=no
trim78 =feat/contact/edge point/default,cartesian
theo/<522.526,773.9,681.851>,<-0.0871557,0,-0.9961947>,<0,-1,0>
actl/<522.538,772.17,681.999>,<-0.0850886,-0.0049411,-0.9963611>,<-0.0034742,-0.9999802,0.0052557>
targ/<522.526,773.9,681.851>,<-0.0871557,0,-0.9961947>,<0,-1,0>
depth=0.3
onerror=no
show hits=no
trim79 =feat/contact/edge point/default,cartesian
theo/<492.15,773.9,707.952>,<-0.9295127,0,-0.36879>,<0,-1,0>
actl/<492.35,772.298,708.033>,<-0.9242647,0.0040276,-0.3817309>,<-0.0043889,-0.9999904,0.0000758>
targ/<492.15,773.9,707.952>,<-0.9295127,0,-0.36879>,<0,-1,0>
depth=0.3
onerror=no
show hits=no
trim80 =feat/contact/edge point/default,cartesian
theo/<466.193,773.9,814.908>,<-0.9729279,0,-0.2311087>,<0,-1,0>
actl/<466.331,772.741,814.937>,<-0.9745997,-0.0002566,-0.223954>,<-0.0005747,-0.9999932,0.0036467>
targ/<466.193,773.9,814.908>,<-0.9729279,0,-0.2311087>,<0,-1,0>
depth=0.3
onerror=no
show hits=no
trim1 =feat/contact/edge point/default,cartesian
theo/<467.212,757.215,858.715>,<-0.1890202,-0.9338508,0.3036346>,<0.4996125,-0.3576535,-0.7889685>
actl/<467.507,755.999,858.261>,<-0.2396446,-0.9408313,0.2395975>,<0.5129491,-0.3322297,-0.7915217>
targ/<467.212,757.215,858.715>,<-0.1890202,-0.9338508,0.3036346>,<0.4996125,-0.3576535,-0.7889685>
depth=0.3
onerror=no
show hits=no
trim2 =feat/contact/edge point/default,cartesian
theo/<494.906,758.073,873.354>,<0.4950016,-0.3577833,-0.7918109>,<0.4950016,-0.3577833,-0.7918109>
actl/<494.594,758.298,873.853>,<-0.8479414,-0.0000039,-0.5300899>,<-0.0977345,-0.8393269,-0.5347694>
targ/<494.906,758.073,873.354>,<0.4950016,-0.3577833,-0.7918109>,<0.4950016,-0.3577833,-0.7918109>
depth=0.3
onerror=no
show hits=no
trim3 =feat/contact/edge point/default,cartesian
theo/<519.261,757.504,886.219>,<0.5105257,-0.2399462,-0.8257053>,<0.5105257,-0.2399462,-0.8257053>
actl/<519.261,757.504,886.219>,<-0.8505536,-0.0000028,-0.5258883>,<0.5105257,-0.2399462,-0.8257053>
targ/<519.261,757.504,886.219>,<0.5105257,-0.2399462,-0.8257053>,<0.5105257,-0.2399462,-0.8257053>
depth=0.3
onerror=no
show hits=no
trim4 =feat/contact/edge point/default,cartesian
theo/<536.823,758.028,899.317>,<0.4878236,-0.3579615,-0.7961732>,<0.4878236,-0.3579615,-0.7961732>
actl/<536.823,758.028,899.317>,<-0.8526749,-0.0000019,-0.5224419>,<0.4878236,-0.3579615,-0.7961732>
targ/<536.823,758.028,899.317>,<0.4878236,-0.3579615,-0.7961732>,<0.4878236,-0.3579615,-0.7961732>
depth=0.3
onerror=no
show hits=no
trim5 =feat/contact/edge point/default,cartesian
theo/<560.304,757.372,911.374>,<0.5029452,-0.2408404,-0.8300856>,<0.5029452,-0.2408404,-0.8300856>
actl/<560.304,757.372,911.374>,<-0.8552605,-0.0000008,-0.5181983>,<0.5029452,-0.2408404,-0.8300856>
targ/<560.304,757.372,911.374>,<0.5029452,-0.2408404,-0.8300856>,<0.5029452,-0.2408404,-0.8300856>
depth=0.3
onerror=no
show hits=no
trim6 =feat/contact/edge point/default,cartesian
theo/<592.565,757.742,933.154>,<0.4784905,-0.3582745,-0.8016771>,<0.4784905,-0.3582745,-0.8016771>
actl/<592.565,757.742,933.154>,<-0.8586793,0.0000007,-0.5125133>,<0.4784905,-0.3582745,-0.8016771>
targ/<592.565,757.742,933.154>,<0.4784905,-0.3582745,-0.8016771>,<0.4784905,-0.3582745,-0.8016771>
depth=0.3
onerror=no
show hits=no
trim7 =feat/contact/edge point/default,cartesian
theo/<638.625,756.462,959.439>,<0.4711159,-0.3585592,-0.8059064>,<0.4711159,-0.3585592,-0.8059064>
actl/<638.625,756.462,959.439>,<-0.86331,0.0000028,-0.504674>,<0.4711159,-0.3585592,-0.8059064>
targ/<638.625,756.462,959.439>,<0.4711159,-0.3585592,-0.8059064>,<0.4711159,-0.3585592,-0.8059064>
depth=0.3
onerror=no
show hits=no
trim8 =feat/contact/edge point/default,cartesian
theo/<671.103,751.131,982.362>,<0.4668144,-0.3534607,-0.8106478>,<0.4668144,-0.3534607,-0.8106478>
actl/<671.103,751.131,982.362>,<-0.8665857,0.0000043,-0.4990283>,<0.4668144,-0.3534607,-0.8106478>
targ/<671.103,751.131,982.362>,<0.4668144,-0.3534607,-0.8106478>,<0.4668144,-0.3534607,-0.8106478>
depth=0.3
onerror=no
show hits=no
trim9 =feat/contact/edge point/default,cartesian
theo/<688.711,747.828,991.482>,<0.4845487,-0.2904796,-0.8251268>,<0.4845487,-0.2904796,-0.8251268>
actl/<688.711,747.828,991.482>,<-0.8623299,0.0000154,-0.5063469>,<0.4844985,-0.290554,-0.82513>
targ/<688.711,747.828,991.482>,<0.4845487,-0.2904796,-0.8251268>,<0.4845487,-0.2904796,-0.8251268>
depth=0.3
avoidance move=no,distance=0
onerror=no
show hits=no
Hi people
I have been given a prototype part to measure and see how close to nominal the dimensions are. I have been given the CAD and...-
05-05-2015, 09:45 AM -
Hi Everyone
I have just started a new program, and started to do a very simple iterative alignment. 3 points for Z and two holes for the...-
05-11-2016, 09:51 AM -
by andrewb91Manual alignment runs correctly, DCC gives the dreaded "Iterative Alignment Error" message.
PNT1 =FEAT/CONTACT/VECTOR...-
05-08-2018, 12:11 PM -
by Simon.DuncanHi Guys, this is probably me being A moron but when I am writing a new program for A new jig we have I import the .IGES file (correct jig, checked multiple...
03-18-2020, 06:37 AM -
by CarfinBear72Looking for some help,
I'm programming a ring with lots of holes on a PCD. Each hole has a 60°c/sink detail on it that requires to be measured....-
11-06-2017, 10:08 AM -
