If you have a FCF with /Profileofasurface/.010/ and the feature is a plane, wouldn't that be the same as /Flat/.010/ ? Just curious. I'm finding some "odd" callouts on this one and wonder what they were thinking.
Flatness vs. Profile
Originally posted by bw_bob View PostProfile controls surface size & flatness is regardless of surface. The only difference I know of.sigpic
Originally posted by Rob_K View PostProfile Could/Not be called toward Datum, while Flatness mustn't. Your example doesn't have any Datum, feature is plane, so /Flat/.010/ would be correct choice.
That is what I was thinking. Why use profile with no datum (form only) on a plane?When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by John Kingston View PostThat is what I was thinking. Why use profile with no datum (form only) on a plane?
Now, engineers will undoubtedly use profile with or without datums in the FCF simply because they will think it ALWAYS means form and location.
Now, if you can check the plane to those tolerances, form and location, NOT form only, then you WILL be in tolerance, even if it is actually form only. No so the other way around. If you are sure your people can continue to make it in tolerance using the more restrictive interpretation, use it.
Also, did the guy who made the print (added the tolerances) KNOW (or could he tell) by looking at a flat, 2-D image, that the surface was in fact a flat plane? If not, (s)he may not have KNOWN it was a flat planar surface and was simply playing a bit of CYA with the print.sigpic
***Profile (no datum ref) is USUALLY reserved for controling co-planarity between 2 surfaces.
It can also be used in other applications (i.e. "profile/position boundary", composite profile..) without a datum ref.
kbRFS Means Really Fussy Stuff
Kevin, isnt profile implied to be parallel unless otherwise specificed were flatness is not?
Originally posted by cmmguy View PostKevin, isnt profile implied to be parallel unless otherwise specificed were flatness is not?
Exp a little more for me if you will, not sure of your intention...RFS Means Really Fussy Stuff
Originally posted by tking View PostAnother question for Kev.
Assume 5 pads that are to be coplaner, one actually.5mm above / below the others. This would pass a .5 flatness test but would fail a .5mm profile test (+/- 0.25mm).
No?
TKsigpic
by dave.hereI have a part with a segmented surface that calls out profile of a surface (see attached). I take several points on each surface and construct a plane...
09-18-2009, 09:25 AM -
by why meIS this even possible Seems like If I have a prof tol of 2.0 then I should have more than 0.5 flattness Tol....
11-15-2011, 03:00 PM -
by April11996
OK,
So our customer transferred parts and we're now making the "same" part for another customer, but they wanted...
03-18-2015, 08:42 AM -
by keegoI have probed a plane of 16 points. When I ask for its flatness I get 0.244 and when I ask for profile/surface form only I get 0.306. What's the difference?...
03-31-2009, 12:34 PM -
by ParkerI have a print calling out Profile of a Surface with no Datum on a plane). I have always considered this basically a Flatness callout. I noticed today...
02-12-2019, 09:52 AM -
