can someone tell what fuction to use to turn off the little red arrows .
this happens when I am touching the part to sellect a plane or anything else .
is there a way to measure a certain feature from a model by just touching the origin and then cliking on the center of a circle just to see what size it is on the X and Y location.or just seeing how big the circle is, hope i didnt confuse anyone.
dont know pc dmiss has that?
to just get nominals from a model put the final alignment on it while offline, then click features with the relevant autofeature window open, pcdmis will populate that window with CAD data as the nominal.
You are going to need the proper alignment and datum on it to get proper nominals, but if that is all you want you can forget the pre-alignment if you don't intend to execute the program on a part
How do you turn of the alarm sound that you get when you remove a probe for cleaning and the probe is off too long? I have one CMM that it goes off and...
