I have a part that calls out .001 flatness per sq inch. Is there a way to call out flatness per sq"?
Flatness Question
Originally posted by BWilliams View PostI have a part that calls out .001 flatness per sq inch. Is there a way to call out flatness per sq"?Last edited by Don Henger; 05-05-2007, 12:41 PM.sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Country Rocks,But Bluegrass RULES!!!
I have done that in the past. Use the past with pattern (like Don mentioned) and you can choose to take as many points as you wish in each 1" segment. Paste with pattern is probably one of my favorite options in PC-DMIS...sigpic
PCDMIS 2012
Windows Office XP
I have done this in the past too. I guess I did it somewhat similar to you guys. I covered the surface with points and then calculated the complete flatness. IF the flatness for ALL points was within the per inch spec, you are sure that the part is always good! But IF it is higher than the per inch spec, I wrote a routine that took some random samples of points making up roughly a sqaure inch. I was lucky, my parts were small, so with about 10 checks, I had a good coverage. But if you have a large part, this can be tedious. Lots of constructions and output.
Originally posted by Jan d. View PostI have done this in the past too. I guess I did it somewhat similar to you guys. I covered the surface with points and then calculated the complete flatness. IF the flatness for ALL points was within the per inch spec, you are sure that the part is always good! But IF it is higher than the per inch spec, I wrote a routine that took some random samples of points making up roughly a sqaure inch. I was lucky, my parts were small, so with about 10 checks, I had a good coverage. But if you have a large part, this can be tedious. Lots of constructions and output.
Jan.sigpic
PCDMIS 2012
Windows Office XP
Any one have a way of dimensioning an entire surface at .001" per square inch
Or a code to do this?
Cant find any luck on the forum...-
03-04-2014, 10:43 AM -
by MFCguyI have never used the pattern or the mirror function. I was wondering how I would accomlish this:
See Attached Sketch.
After I have...-
01-24-2008, 09:51 AM -
by MidwestStill learning........
What would be the basic steps involved in using my cmm to measure the flatness of a washer, taking 60 hits on the top surface?...-
02-28-2013, 12:24 PM -
Hello All! I have a moving flatness callout for a group of housings developed by Allison Transmission. They want an overall Flatness .050mm, but then...
02-19-2015, 08:42 AM -
by MikeFon the help it shows a square and mine shows only a X, the drawing calls for flatness .001 per inch how would i do this?...
07-09-2021, 10:50 AM -
