I am programming surface profiles using the ASME Y14.5 standard, should this not give me double the maximum dimension as my deviation? I am currently getting max - min as my deviation. I have tried changing the setting in the Settings Editor to USEISOCALCULATIONS=1 but that made no difference.
ASME Y14.5 PCDMIS 2017 R1 surface profile dimensioning
Originally posted by jherr70 View PostI am programming surface profiles using the ASME Y14.5 standard, should this not give me double the maximum dimension as my deviation? I am currently getting max - min as my deviation. I have tried changing the setting in the Settings Editor to USEISOCALCULATIONS=1 but that made no difference.
bfire85 is correct about XactMeasure reporting Max & Min for ASME profile.
However, with 2020 R2 we are replacing XactMeasure with the new geometric tolerance command and this will support the newer ASME single value interpretation for profile.
- 1 like
There's a thread in the technical preview area of the forum (if you've signed up) and there was a webinar a few weeks ago https://www.hexagonmi.com/about-us/e...o-deal-with-it
- 3 likes
by johnnyrocketGreetings,
I am pretty sure these questions has been asked ad nauseam, so please forgive me.
Where Profile of a surface is...-
11-03-2018, 09:49 AM -
by ALousyUserGood afternoon. I'm trying to see if I can get PCDMIS to transfer just the total surface profile over to QC-Calc. Right now, I've got the total surface...
10-27-2020, 12:08 PM -
by newsitechrisSometimes while using PC-DMIS, I have a surface or line profile called out on the print. Say for example, a surface profile is called out 1/A/B/C. I...
06-28-2017, 08:29 AM -
by TIMSHARMANHi there I hope somebody can help with the following that knows the difference between asme and iso standards in regards to reporting profile, I currently...
01-16-2013, 11:43 AM -
by Jonde1More of a Standard, GD&T issue rather than PC-dmis
Our customer seems to think that when reporting a profile to ASME Y14.5 you should...-
08-16-2017, 03:26 AM -
