Global IF GO TO command
  • Global IF GO TO command
    Can I write a global command that IF anything is OUTTOL then GO TO label or do I have to code it individually for each dimension out-put?
    example of individual coding:
      IF_GOTO/F54.OUTTOL,GOTO = L1
    L1         =LABEL/
    My end goal is to have a comment pop-up providing the operator with detailed instructions if anything is OUTTOL
    Jesse Krook
    Here is code that I put together with help from a few other programmers and it works good. Need the script below to make it work
    CS2 =SCRIPT/FILENAME= F:\USERS\CMMUSER\CMM_PROGRAMS(PCDMIS)\OUTTOL.BAS
    FUNCTION/Main,SHOW=YES,,
    STARTSCRIPT/
    ENDSCRIPT/
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,OVERWRITE=VAL_FILE,$
    TO_PRINTER=OFF,$
    IF/NUMBEROUTTOL > .1
    GOTO/PRINT_FAIL
    END_IF/
    This is a script that Craiger wrote for me many years ago. Change the filename extension after you download it and use it in the code posted above
    Contura Calypso 5.4
