FCF issues
  • FCF issues
    I am having an odd issue trying to create a profile dimension. I have attached a PDF of a mockup drawing that is the same layout as my part.
    The part is currently aligned so that datum A is facing the X-Plus direction (datum B as well obviously). When I try to create the FCF for the .002 profile tolerance, I get crazy out-of-tolerance numbers (like .5752), even though everything is currently at nominal. I did read somewhere that PC-DMIS requires the primary datum to be aligned to Z-Plus before creating the dimension, but I was still not able to get the profile dimension to work even with changing the alignment so that datum A is aligned to Z-Plus. Has anyone else had this kind of issue?
    I have also tried constructing datum B as both a cylinder and as a circle and did not have any luck.
    How are you clocking your coordinate system? Can you attach a snip of the report, including datum shift and measured values (the lower two sections)?
      I'm not clocking the coordinate system in the FCF. For the part alignment I'm just using the top plane to rotate the alignment.
      I hadn't thought to look at the datum shift, that's definitely where the crazy numbers are coming from.. but why would PC-DMIS be shifting the datum like that? Wouldn't it use the part alignment as the default and the shift the datum to best-fit the features?
        It will use whatever alignment you have set. That's why I asked which way you clocked it. If all you did was a level and an origin alignment (no rotate) then PC-DMIS will act up in a case like this (not symmetrical about the axis of datum B).
        When you set your alignment, do you first level, then rotate, then origin?
          I believe it is level, origin, then rotate. I'll try doing the rotate before origin.
            I switched the order of the alignment, but the report is the same.
              What are you rotating to? Also, are you rotating about XPLUS?
                The plane facing Z-Plus (I drew an arrow pointing at it in the picture).
                Yes, it is rotating about X-Plus
                  Can you attach your code? I suspect something is flipped, because it is attempting to rotate about datum B by ~270 degrees (essentially 90) to optimize your result. Something is off by 90 degrees.
                    That would make sense. Here's the applicable code.
                    ALIGNMENT/END
                    MODE/MANUAL
                    LOADPROBE/2 X 20
                    TIP/T1A90B-90, SHANKIJK=1, 0, 0, ANGLE=-90
                    PLACE PROBE LEVEL WITH AND CENTERED ON HOLE IN CENTER OF PART
                    PNT1 =FEAT/POINT,CARTESIAN
                    THEO/<0.0394,0,0>,<1,0,0>
                    ACTL/<0.0394,0,0>,<1,0,0>
                    READPOINT/
                    READY FOR DCC!
                    MODE/DCC
                    ALIGNMENT/TRANS,XAXIS,PNT1
                    ALIGNMENT/TRANS,YAXIS,PNT1
                    ALIGNMENT/TRANS,ZAXIS,PNT1
                    ALIGNMENT/TRANS_OFFSET,XAXIS,-0.0394
                    ALIGNMENT/END
                    FLY/ON
                    MOVESPEED/ 50
                    PREHIT/0.1
                    RETRACT/0.1
                    TOUCHSPEED/ 5
                    CLEARP/XPLUS,0.5,XPLUS,0.5,OFF
                    FIND_CENTER=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
                    THEO/<0,0,0>,<1,0,0>,0.25
                    ACTL/<0,0,0>,<1,0,0>,0.25
                    TARG/<0,0,0>,<1,0,0>
                    START ANG=0,END ANG=360
                    ANGLE VEC=<0,0,-1>
                    DIRECTION=CCW
                    SHOW FEATURE PARAMETERS=NO
                    SHOW CONTACT PARAMETERS=YES
                    NUMHITS=5,DEPTH=0.1,PITCH=0
                    SAMPLE METHOD=SAMPLE_HITS
                    SAMPLE HITS=0,SPACER=0
                    AVOIDANCE MOVE=AFTER,DISTANCE=0.1
                    FIND HOLE=CENTER,ONERROR=NO,READ POS=NO
                    SHOW HITS=YES
                    HIT/BASIC,<-0.1,0,-0.125>,<0,0,1>,<-0.1,0,-0.125>
                    HIT/BASIC,<-0.1,0.1189,-0.0386>,<0,-0.9510565,0.309017>,<-0.1,0.1189,-0.0386>
                    HIT/BASIC,<-0.1,0.0735,0.1011>,<0,-0.5877853,-0.809017>,<-0.1,0.0735,0.1011>
                    HIT/BASIC,<-0.1,-0.0735,0.1011>,<0,0.5877853,-0.809017>,<-0.1,-0.0735,0.1011>
                    HIT/BASIC,<-0.1,-0.1189,-0.0386>,<0,0.9510565,0.309017>,<-0.1,-0.1189,-0.0386>
                    ENDMEAS/
                    FIND_PLANE =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,OUTLINE,LEAST_SQR
                    THEO/<0,0.0776,0.2962>,<1,0,0>
                    ACTL/<0,0.0776,0.2962>,<1,0,0>
                    TARG/<0,0.0776,0.2962>,<1,0,0>
                    ANGLE VEC=<0,0,-1>,SQUARE
                    NUMHITS=2,NUMROWS=2
                    SPACER=0
                    AVOIDANCE MOVE=BOTH,DISTANCE=0.1
                    USE BOUNDARY OFFSET=YES,OFFSET=32.258
                    SHOW HITS=YES
                    HIT/BASIC,<0,-0.1572,0.1556>,<1,0,0>,<0,-0.1572,0.1556>
                    HIT/BASIC,<0,-0.1572,-0.1556>,<1,0,0>,<0,-0.1572,-0.1556>
                    HIT/BASIC,<0,0.1572,-0.1556>,<1,0,0>,<0,0.1572,-0.1556>
                    HIT/BASIC,<0,0.1572,0.1556>,<1,0,0>,<0,0.1572,0.1556>
                    ENDMEAS/
                    ALIGNMENT/LEVEL,XPLUS,FIND_PLANE
                    ALIGNMENT/TRANS,XAXIS,FIND_PLANE
                    ALIGNMENT/TRANS,YAXIS,FIND_CENTER
                    ALIGNMENT/TRANS,ZAXIS,FIND_CENTER
                    ALIGNMENT/END
                    MOVE/CLEARPLANE
                    FIND_PLANE_2=FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,OUTLINE,LEAST_SQR
                    THEO/<-0.0949,-0.0221,0.4>,<0,0,1>
                    ACTL/<-0.0949,-0.0221,0.4>,<0,0,1>
                    TARG/<-0.0949,-0.0221,0.4>,<0,0,1>
                    ANGLE VEC=<-1,0,0>,SQUARE
                    NUMHITS=2,NUMROWS=2
                    SPACER=0
                    USE BOUNDARY OFFSET=YES,OFFSET=16.129
                    SHOW HITS=YES
                    HIT/BASIC,<-0.025,0.0685,0.4>,<0,0,1>,<-0.025,0.0685,0.4>
                    HIT/BASIC,<-0.395,0.0685,0.4>,<0,0,1>,<-0.395,0.0685,0.4>
                    HIT/BASIC,<-0.395,-0.0685,0.4>,<0,0,1>,<-0.395,-0.0685,0.4>
                    HIT/BASIC,<-0.025,-0.0685,0.4>,<0,0,1>,<-0.025,-0.0685,0.4>
                    ENDMEAS/
                    A3 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                    ALIGNMENT/ROTATE,ZPLUS,TO,FIND_PLANE_2,ABOUT,XPLUS
                    ALIGNMENT/END
                    MOVE/CLEARPLANE
                    DATUM_A_PLANE=FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,OUTLINE,LEAST_SQR
                    THEO/<0,0.0565,-0.1954>,<1,0,0>
                    ACTL/<0,0.0565,-0.1954>,<1,0,0>
                    TARG/<0,0.0565,-0.1954>,<1,0,0>
                    NUMHITS=3,NUMROWS=4
                    SPACER=0
                    SHOW HITS=YES
                    HIT/BASIC,<0,-0.2072,0.0938>,<1,0,0>,<0,-0.2072,0.0938>
                    HIT/BASIC,<0,-0.2072,-0.0938>,<1,0,0>,<0,-0.2072,-0.0938>
                    HIT/BASIC,<0,-0.0774,-0.1406>,<1,0,0>,<0,-0.0774,-0.1406>
                    HIT/BASIC,<0,-0.0774,0.1406>,<1,0,0>,<0,-0.0774,0.1406>
                    HIT/BASIC,<0,-0.0774,0.375>,<1,0,0>,<0,-0.0774,0.375>
                    HIT/BASIC,<0,0.0774,0.375>,<1,0,0>,<0,0.0774,0.375>
                    HIT/BASIC,<0,0.0774,0.1406>,<1,0,0>,<0,0.0774,0.1406>
                    HIT/BASIC,<0,0.0774,-0.1406>,<1,0,0>,<0,0.0774,-0.1406>
                    HIT/BASIC,<0,0.2072,-0.0938>,<1,0,0>,<0,0.2072,-0.0938>
                    HIT/BASIC,<0,0.2072,0.0938>,<1,0,0>,<0,0.2072,0.0938>
                    ENDMEAS/
                    DATUM_B_BORE=FEAT/CONTACT/CYLINDER/DEFAULT,CARTESIAN,IN,LEAST_SQR
                    THEO/<0,0,0>,<1,0,0>,0.25,0.42
                    ACTL/<0,0,0>,<1,0,0>,0.25,0.42
                    ANGLE VEC=<0,0,-1>
                    DIRECTION=CCW
                    NUMHITS=12,NUMLEVELS=3,DEPTH=0.05,END OFFSET=0.05,PITCH=0
                    SHOW HITS=YES
                    HIT/BASIC,<-0.05,0,-0.125>,<0,-0.0000401,1>,<-0.05,0,-0.125>
                    HIT/BASIC,<-0.05,0.0597,-0.1098>,<0,-0.4777373,0.8785028>,<-0.05,0.0597,-0.1098>
                    HIT/BASIC,<-0.05,0.1074,-0.0639>,<0,-0.8592849,0.5114974>,<-0.05,0.1074,-0.0639>
                    HIT/BASIC,<-0.05,0.1249,-0.0043>,<0,-0.9994211,0.0340216>,<-0.05,0.1249,-0.0043>
                    HIT/BASIC,<-0.05,0.1103,0.0589>,<0,-0.8821838,-0.4709053>,<-0.05,0.1103,0.0589>
                    HIT/BASIC,<-0.05,0.0614,0.1089>,<0,-0.4912673,-0.8710088>,<-0.05,0.0614,0.1089>
                    HIT/BASIC,<-0.05,-0.0017,0.125>,<0,0.0136107,-0.9999074>,<-0.05,-0.0017,0.125>
                    HIT/BASIC,<-0.05,-0.0648,0.1069>,<0,0.518261,-0.8552225>,<-0.05,-0.0648,0.1069>
                    HIT/BASIC,<-0.05,-0.112,0.0554>,<0,0.8963694,-0.4433079>,<-0.05,-0.112,0.0554>
                    HIT/BASIC,<-0.05,-0.1248,-0.0077>,<0,0.9980973,0.0616585>,<-0.05,-0.1248,-0.0077>
                    HIT/BASIC,<-0.05,-0.1032,-0.0705>,<0,0.8255178,0.5643761>,<-0.05,-0.1032,-0.0705>
                    HIT/BASIC,<-0.05,-0.0493,-0.1149>,<0,0.3944846,0.9189025>,<-0.05,-0.0493,-0.1149>
                    HIT/BASIC,<-0.21,-0.0493,-0.1149>,<0,0.3944846,0.9189025>,<-0.21,-0.0493,-0.1149>
                    HIT/BASIC,<-0.21,-0.1032,-0.0705>,<0,0.8255178,0.5643761>,<-0.21,-0.1032,-0.0705>
                    HIT/BASIC,<-0.21,-0.1248,-0.0077>,<0,0.9980973,0.0616585>,<-0.21,-0.1248,-0.0077>
                    HIT/BASIC,<-0.21,-0.112,0.0554>,<0,0.8963694,-0.4433079>,<-0.21,-0.112,0.0554>
                    HIT/BASIC,<-0.21,-0.0648,0.1069>,<0,0.518261,-0.8552225>,<-0.21,-0.0648,0.1069>
                    HIT/BASIC,<-0.21,-0.0017,0.125>,<0,0.0136107,-0.9999074>,<-0.21,-0.0017,0.125>
                    HIT/BASIC,<-0.21,0.0614,0.1089>,<0,-0.4912673,-0.8710088>,<-0.21,0.0614,0.1089>
                    HIT/BASIC,<-0.21,0.1103,0.0589>,<0,-0.8821838,-0.4709053>,<-0.21,0.1103,0.0589>
                    HIT/BASIC,<-0.21,0.1249,-0.0043>,<0,-0.9994211,0.0340216>,<-0.21,0.1249,-0.0043>
                    HIT/BASIC,<-0.21,0.1074,-0.0639>,<0,-0.8592849,0.5114974>,<-0.21,0.1074,-0.0639>
                    HIT/BASIC,<-0.21,0.0597,-0.1098>,<0,-0.4777373,0.8785028>,<-0.21,0.0597,-0.1098>
                    HIT/BASIC,<-0.21,0,-0.125>,<0,-0.0000401,1>,<-0.21,0,-0.125>
                    HIT/BASIC,<-0.37,0,-0.125>,<0,-0.0000401,1>,<-0.37,0,-0.125>
                    HIT/BASIC,<-0.37,0.0597,-0.1098>,<0,-0.4777373,0.8785028>,<-0.37,0.0597,-0.1098>
                    HIT/BASIC,<-0.37,0.1074,-0.0639>,<0,-0.8592849,0.5114974>,<-0.37,0.1074,-0.0639>
                    HIT/BASIC,<-0.37,0.1249,-0.0043>,<0,-0.9994211,0.0340216>,<-0.37,0.1249,-0.0043>
                    HIT/BASIC,<-0.37,0.1103,0.0589>,<0,-0.8821838,-0.4709053>,<-0.37,0.1103,0.0589>
                    HIT/BASIC,<-0.37,0.0614,0.1089>,<0,-0.4912673,-0.8710088>,<-0.37,0.0614,0.1089>
                    HIT/BASIC,<-0.37,-0.0017,0.125>,<0,0.0136107,-0.9999074>,<-0.37,-0.0017,0.125>
                    HIT/BASIC,<-0.37,-0.0648,0.1069>,<0,0.518261,-0.8552225>,<-0.37,-0.0648,0.1069>
                    HIT/BASIC,<-0.37,-0.112,0.0554>,<0,0.8963694,-0.4433079>,<-0.37,-0.112,0.0554>
                    HIT/BASIC,<-0.37,-0.1248,-0.0077>,<0,0.9980973,0.0616585>,<-0.37,-0.1248,-0.0077>
                    HIT/BASIC,<-0.37,-0.1032,-0.0705>,<0,0.8255178,0.5643761>,<-0.37,-0.1032,-0.0705>
                    HIT/BASIC,<-0.37,-0.0493,-0.1149>,<0,0.3944846,0.9189025>,<-0.37,-0.0493,-0.1149>
                    ENDMEAS/
                    MOVE/CLEARPLANE
                    TOP_PLANE =FEAT/CONTACT/PLANE/DEFAULT,CARTESIAN,OUTLINE,LEAST_SQR
                    THEO/<-0.101,-0.054,0.4>,<0,0,1>
                    ACTL/<-0.101,-0.054,0.4>,<0,0,1>
                    TARG/<-0.101,-0.054,0.4>,<0,0,1>
                    NUMHITS=2,NUMROWS=3
                    SPACER=0
                    SHOW HITS=YES
                    HIT/BASIC,<-0.395,0,0.4>,<0,0,1>,<-0.395,0,0.4>
                    HIT/BASIC,<-0.025,0,0.4>,<0,0,1>,<-0.025,0,0.4>
                    ENDMEAS/
                    A4 =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
                    ALIGNMENT/LEVEL,XPLUS,DATUM_A_PLANE
                    ALIGNMENT/ROTATE,ZPLUS,TO,TOP_PLANE,ABOUT,XPLUS
                    ALIGNMENT/TRANS,XAXIS,DATUM_A_PLANE
                    ALIGNMENT/TRANS,YAXIS,DATUM_B_BORE
                    ALIGNMENT/TRANS,ZAXIS,DATUM_B_BORE
                    ALIGNMENT/END
                      Part 2
                      (In between these code blocks I take a bunch of hits around the part. OUTSIDE_SET is the set of points around the part)
                      DATDEF/A,FEATURES=DATUM_A_PLANE,,
                      DATDEF/B,FEATURES=DATUM_B_BORE,,
                      COMMENT/REPT,
                      BALLOON NO.04, [PG.01,GRID C:4]
                      OUTSIDE_SET=FEAT/SET,CARTESIAN
                      THEO/<-0.21,0.0003,0.0393>,<0,0,1>
                      ACTL/<-0.21,0.0003,0.0393>,<0,0,1>
                      CONSTR/SET,BASIC,OUTSIDE_ARC_1.HIT[1..1],OUTSIDE_ARC_1.HIT[2..2],OUTSIDE_ARC_1.HIT[3..3],OUTSIDE_ARC_1.HIT[4..4],OUTSIDE_ARC_1.HIT[5..5],OUTSIDE_LINE_1.HIT[1..1],OUTSIDE_LINE_1.HIT[2..2],OUTSIDE_LINE_1.HIT[3..3],OUTSIDE_ARC_2.HIT[1..1],$
                      OUTSIDE_ARC_2.HIT[2..2],OUTSIDE_ARC_2.HIT[3..3],OUTSIDE_ARC_2.HIT[4..4],OUTSIDE_ARC_2.HIT[5..5],OUTSIDE_PLANE_1.HIT[1..1],OUTSIDE_PLANE_1.HIT[4..4],OUTSIDE_PLANE_1.HIT[5..5],OUTSIDE_ARC_9.HIT[1..1],OUTSIDE_ARC_9.HIT[2..2],$
                      OUTSIDE_ARC_9.HIT[3..3],OUTSIDE_ARC_9.HIT[4..4],OUTSIDE_ARC_9.HIT[5..5],OUTSIDE_LINE_5.HIT[1..1],OUTSIDE_LINE_5.HIT[2..2],OUTSIDE_LINE_5.HIT[3..3],OUTSIDE_ARC_10.HIT[5..5],OUTSIDE_ARC_10.HIT[4..4],OUTSIDE_ARC_10.HIT[3..3],$
                      OUTSIDE_ARC_10.HIT[2..2],OUTSIDE_ARC_10.HIT[1..1],OUTSIDE_PLANE_2.HIT[6..6],OUTSIDE_PLANE_2.HIT[3..3],OUTSIDE_PLANE_2.HIT[2..2],OUTSIDE_ARC_3.HIT[1..1],OUTSIDE_ARC_3.HIT[2..2],OUTSIDE_ARC_3.HIT[3..3],OUTSIDE_ARC_3.HIT[4..4],$
                      OUTSIDE_ARC_3.HIT[5..5],OUTSIDE_LINE_2.HIT[1..1],OUTSIDE_LINE_2.HIT[2..2],OUTSIDE_LINE_2.HIT[3..3],OUTSIDE_ARC_4.HIT[1..1],OUTSIDE_ARC_4.HIT[2..2],OUTSIDE_ARC_4.HIT[3..3],OUTSIDE_ARC_4.HIT[4..4],OUTSIDE_ARC_4.HIT[5..5],$
                      OUTSIDE_ARC_5.HIT[1..1],OUTSIDE_ARC_5.HIT[2..2],OUTSIDE_ARC_5.HIT[3..3],OUTSIDE_ARC_5.HIT[4..4],OUTSIDE_ARC_5.HIT[5..5],OUTSIDE_LINE_3.HIT[1..1],OUTSIDE_LINE_3.HIT[2..2],OUTSIDE_LINE_3.HIT[3..3],OUTSIDE_ARC_6.HIT[1..1],$
                      OUTSIDE_ARC_6.HIT[2..2],OUTSIDE_ARC_6.HIT[3..3],OUTSIDE_ARC_6.HIT[4..4],OUTSIDE_ARC_6.HIT[5..5],OUTSIDE_PLANE_2.HIT[1..1],OUTSIDE_PLANE_2.HIT[4..4],OUTSIDE_PLANE_2.HIT[5..5],OUTSIDE_PLANE_1.HIT[6..6],OUTSIDE_PLANE_1.HIT[3..3],$
                      OUTSIDE_PLANE_1.HIT[2..2],OUTSIDE_ARC_7.HIT[1..1],OUTSIDE_ARC_7.HIT[2..2],OUTSIDE_ARC_7.HIT[3..3],OUTSIDE_ARC_7.HIT[4..4],OUTSIDE_ARC_7.HIT[5..5],OUTSIDE_LINE_4.HIT[1..1],OUTSIDE_LINE_4.HIT[2..2],OUTSIDE_LINE_4.HIT[3..3],$
                      OUTSIDE_ARC_8.HIT[1..1],OUTSIDE_ARC_8.HIT[2..2],OUTSIDE_ARC_8.HIT[3..3],OUTSIDE_ARC_8.HIT[4..4],OUTSIDE_ARC_8.HIT[5..5],,
                      NO.04 =SURFACE PROFILE : OUTSIDE_SET
                      FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES,
                      CADGRAPH=OFF,REPORTGRAPH=OFF,TEXT=OFF,MULT=10.00,A RROWDENSITY=100,OUTPUT=BOTH,UNITS=IN,
                      COMPOSITE=NO,
                      CUSTOMIZED DRF=NO
                      STANDARDTYPE=ASME_Y14_5
                      PRIMARY DIMENSION/PROFILE OF SURFACE,0.002,<UZ>,<UTol>,A,B,<dat>
                      NOTE/NO.04
                      FEATURES/OUTSIDE_SET,,
                        CREATE AN ANALYSIS, Maybe your taking a bad hit, INSERT/REPORT COMMAND/ANALYSIS. choose your Profile hit apply, show all arrows, and View Window. Lets take a looksy at your result.
                        • akoiro
                          akoiro commented
                          Thanks! This is a good tool to keep in mind, I've never used analysis. In this case though, I'm still just programming, all of the measured values are at nominal.
                        Your workplane should be XPLUS. Think about it, you are measuring a circle in the YZ plane while using ZPLUS workplane. That will appear to PC-DMIS as a line.
                        Also, if that doesn't fix it, can you share code with actual values?
                        • akoiro
                          akoiro commented
                          That's very true! I updated the workplane, but it doesn't seem to make any difference. I was measuring most of the features as 3D features (planes and cylinders). I'll take a closer look at it with the workplane in mind tomorrow.
                        I'm just going to through this out there.
                        If I were to write this program I would place datum A facing in the Z direction (Global S Chrome 9-12-08) for ease of programming and measuring the part. Just my opinion.
                        2024 can't get here soon enough!!!
                        • akoiro
                          akoiro commented
                          Yes, I agree. The actual part is a little different than what I posted here though, there are other features that make this setup a better option.
                        When doing alignment bear in the mind that should bet eliminated 5 degrees of freedom at least (best case 6 but it is impossible to do for turned symmetrical parts)
                        You alignment A3 is the same as A2 except fixed rotation problem (should not be problem). Then I see alignment A4 which looks good. Overall I couldn't find anything wrong.
                        I could only share how I would do it.
                        Usually I do use iterative alignment it is simple and do not change coordinate system.Every feature I do mark as per translate degrees of freedom (PNTX1,PNTX2, PNTX3 etc.) and giving output in a report, if as example PNTX2 have deviation as example 0.001 as per X axis that indicating alignment problems. As usual two iterations giving proper alignment. Then I do measure profile by points, then construct "feature set", then output. In a case as yours, when I can't get why output of profile isn't reasonable I'm using output T, it showing material on/off related to alignment. And after this I would just grab mechanical equipment and double check. Other easier but less precise way is to do graphical analysis.
