Display Dimension Info For all Dimensons (Graphic Window)
  • Display Dimension Info For all Dimensons (Graphic Window)
    I understand that you can check the "Display" option under "Dimension Info" within each dimension dialog box. Is there a way to turn all of these on at once for all dimensions? I have tried Operation (Drop Down)/Graphic Display Window/Graphic Items/Show Dimension Info label ID's but nothing appears on screen. I am looking to show the label ID's only. Thanks
    Feature label or dimension label? To get the dimension label, you will have to create DIMINFO's in the program. INSERT ~ REPORT COMMMAND ~ DIMENSION INFO. Then in the pop-up, select all the dimensions, and UNMARK every option except SHOW DIMENSION ID
      If it is just the Id's you want to show, put your cursor at the of your routine then got to EDIT>GRAPHICS DISPLAY WINDOW>FEATURE APPEARANCE. Select all of the features in the list and then select what you want to display (feature's or Labels). Dimension Info's will only display if they have previously been created in the routine. If you want to create multiple dimension info commands in one go, try INSERT>REPORT COMMAND>DIMENSION INFO.
      Neil Challinor
      PC-DMIS Product Owner
      E: [email protected]
        Got it now with the Insert>Report Command>Dimension Info. Thanks!
