2020 r1 sp4
  • 2020 r1 sp4
    here :
    https://www.wilcoxassoc.com/public/P...20_R1/SP4/x64/
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...20_R1/SP4/x64/
    Release Notes - 2020 R1 SP4
    • PCD-145735 - Fixed an issue where the Analysis View was different when you viewed it in the Custom Report and Report windows.
    • PCD-147397 - Fixed an issue where the vectors and sizes were incorrect when you used the Create Multiple Features check box in the Auto Feature dialog box for Flush and Gap.
    • PCD-154534 - Fixed an issue where the report modifications weren't applied to the report when you used a custom report.
    • PCD-155187 - Fixed an issue where the mouse pointer was shown as an hourglass when you selected curves on the CAD model to create multiple Laser Edge Point features.
    • PCD-158031. Fixed an issue where PC-DMIS displayed a message about the failure to load the HSI.DLL library when you opened PC-DMIS.
    • PCD-163049 - Fixed an issue where the T-probe button was not able to close the Probe Measurement Failed message box when you tried to take points.
    • PCD-164604 - Fixed a software crash that occurred when you clicked Cancel in the Snapshot dialog box.
    • PCD-169301 - Fixed an issue where the labels were lost when you doubleclicked on the image in the Report window to edit the Analysis View command.
    • PCD-170663 - Fixed a hardware crash that occurred when an invalid tip was created for a probe.
    • PCD-175235 - Fixed an issue where relative measure doesn't work when you selected multiple features from the Graphic Display window.
    • PCD-176498 - Fixed an issue where the pointcloud exclusion plane was connected to an incorrect plane when you executed a measurement routine.
    • PCD-177160 - Fixed an issue where PC-DMIS wouldn't automatically switch the Edit window to Summary Mode when you edited a custom report.
    • PCD-177755 - Fixed an issue where PC-DMIS showed incorrect symbols for deviations in a custom report when you used positive reporting for all axes.
    • PCD-177971 - Fixed an issue where PC-DMIS showed incorrect point positions in the CAD report when the points were used in the loop instructions.
    • PCD-180323 - Fixed an issue where the pointcloud and mesh data objects were highlighted when you selected points in the Auto Features dialog box.
    • PCD-181805 - Fixed an issue where PC-DMIS didn't update the leader lines with arrow heads in the Report window when you changed the Arrow head option in the Label Layout Wizard dialog box.
    • PCD-183229 - Fixed an issue where PC-DMIS didn't show the correct number of digits after the decimal when you generated the Excel Form report.
    • PCD-185194 - Fixed an issue where the colormap annotations were evaluated at 0,0,0 position when you executed a measurement routine.
    • PCD-186532 - Fixed a software crash that occurred when you tried to tesellate certain probe components.
    • PCD-186676 - Fixed an issue where the report label changed its position in a custom report when you closed and reopened a measurement routine.
    • PCD-187386 - Fixed an issue where the 3D Grid lines wouldn't display properly in the Graphic Display window after you took a snapshot.
    • PCD-187660 - Fixed an issue where PC-DMIS didn't associate a label template file when the dragged the ESF features in the Edit window.
    • PCD-187890 - Fixed an issue where the colormap gradient scale was not shown in the Graphic Display window when you loaded a different scale profile that wasn't the default one from the Profiles Manager dialog box.
    • PCD-188182 - Fixed an issue where PC-DMIS inserted an additional MOVE/CLEARPLANE command before the Roughness scan command when you clicked OK in the Roughness Scan dialog box.
    • PCD-188204 - Fixed an issue where PC-DMIS didn't scan properly on the machine when you scanned small size holes.
    • PCD-188449 - Fixed an issue where Q-DAS Configurator wouldn't report the maximum and minimum values for legacy profile of surface of a plane (Form Only).
    • PCD-188578 - Fixed an issue where the diameter of the circle was calculated incorrectly when you selected MIN_SEP (Best Fit type) in the Auto Features dialog box.
    • PCD-188888 - Fixed an issue where the Thickness Colormap scale values were incorrect in the Mesh Operator dialog box when you didn't mark the Compare to CAD check box.
    • PCD-189732 - Fixed an issue where the CAD window displayed the elements and their Ids when you generated the legacy report.
    • PCD-190603 - Fixed an issue where PC-DMIS didn't update the CAD Setup Toolbar list with the standard CAD model views when you imported a CAD file.
    • PCD-190622 - Fixed a software crash that occurred when you typed a nonexisting Mesh ID for the MESH/OPER command in the Edit window.
    • PCD-191391 - Fixed an issue where PC-DMIS automatically unmarked the Symmetrical check box when you changed the feature type in the Extended Sheet Metal Features dialog box.
    • PCD-191441 - Fixed an issue that occurred when you didn't center the calibration slide rectangle at the beginning of the pixel size calibration, it caused distortion calibration failure after PC-DMIS prompts you to retry the calibration.
    • PCD-191484 - Fixed an issue where the Colormaps list was disabled when the measurement routine doesn't contain a pointcloud.
    • PCD-192421 - Fixed a software crash that occurred when the On Error command failed to set a variable.
    • PCD-193410 - Fixed a collision issue that occurred when an incorrect wrist position failed to recover a probe change from Contact to Laser.
    • PCD-193699 - Fixed an issue where the Thickness Colormap gradient scale value showed a negative percentage at the lowest level when you didn't mark the Compare to CAD check box.
    • PCD-194186 - Fixed an issue where PC-DMIS didn't update the temperature values in the report when you used the Temperature Compensation version 1 dialog box. To use version 1 dialog box, set the UseTemperatureCompensationV2 registry entry to False in PC-DMIS Settings Editor.
    • PCD-194646 - Fixed an issue where PC-DMIS Home page Internet access settings were on a per user rather than a global setting for all users.
    • PCD-194926 - Fixed an issue with the I++ DME client where indexing head support was incorrect due to a mistake with how angles were treated if they were not reported from the I++ server.
    • PCD-195737 - Fixed an issue where an improper move in an incorrect direction occurred at the start of a Defined Scan with a Zeiss VAST XT probe when a measurement routine used Imperial units.
