Spent an hour or so looking in the forum to see if this problem was had by anyone else. It was not. Or I couldn't find it.
Here's the setup: PCDMIS 3.7 MR3. Scirrocco with PH10m/TP200B/ with 4x50 and 2x30 tips each on it's own magnetic module. Both are setup and qualified at A0B0. Tip changes are made manually.
The problem: During a measurement using the 4x50 tip, part alignment is made and Z is set to the top of the part. Later in the program I change to the 2x30 tip. When I hit on the top surface of the part it measures .904 when it should read 0.000.
I made a simple program using both tips measuring my qual sphere. The first tip measures the qual sphere and the alignment is made to the center of the results. The second tip is loaded and the same qual sphere is measured. The measurement results made by the second tip showed the sphere xyz to be
-.336, .336, .904 (should be 0,0,0 within a few microns)
The diameter results from the second tip is correct.
Any ideas?
Any ideas?
