Got a weird error message on PC-DMIS. Not sure what it's about, but I'm not having any problem running the software. Just wondered if anyone else had encountered this and how to fix it.
Weird error message
Looks like a Datapage+ error message to me. Make sure both PC-Dmis and the .exe you are launching are set to run as administrator.
Yes, I think it is a Datapage error. How can I make sure that they are both set to run as administrator and that they do that every time they are executed? There is a line of code that we use to save to Datapage, but I never mess with the software itself, so I don't even know if it's running in the background or if it launches every time it reads that code.
Right click on the .exe, properties,compatability, tick the "run this program as administrator" box. If you're running windows 10 you will need to navigate to the PCDLRN.exe in the install folder (usually C;\program files\hexagon\pc-dmis\version. On older systems (windows 7) you can right click from the start menu.
Did you also set the .exe that the external command is launching to run as administrator. If I remember correctly it will be called some thing like datapagestats.exe and you should be able to see the file path in the external command.
Neil is 100% correct here, you need to find the "datapagestats.exe" file that you're trying to launch in PC-DMIS and in the compatibility settings in the Windows properties change it to "run as administrator" for all users. You should enlist the help of your IT department.
by wsneedenI am wondering if anyone has ever encountered this error message before....
When opening PCDMIS I receive an error message of 'error in...-
06-03-2015, 08:34 AM -
by GuestHas any one seen this Error message? If so what is going on? B&S ONE with PcDmis 3.7...
11-27-2007, 09:40 AM -
by bamlinI have two PCDemon seats... same versions on both (4.2MR1). When I run a program on Machine #1 and want to stop the program it gives me an "error...
01-13-2010, 12:46 PM -
by GuestI get the error message of "GPIB error" message after trying to open PC-DMIS for Windoww 3.5 and PC-DMIS for Windows 3.7.
Does...-
04-05-2006, 04:53 PM -
by kellyhEvery once in a while during my OLE, I get a server busy message with three buttons, switch to, retry, and cancel (greyed out).
I have...-
Channel: PC-DMIS Code Samples
09-25-2013, 11:59 AM -
