Here :
ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...9_R1/SP10/x64/
Release Notes - 2019 R1 SP10
•PCD-47924 - Fixed an issue where PC-DMIS didn't execute the Go 6DoFcommand when you pressed Alt + F9 for the AT960 and AT901 trackers.
•PCD-147397 - Fixed an issue where the vectors and sizes were incorrect when you used the Create Multiple Featurescheck box in the Auto Featuredialog box for Flush and Gap.
•PCD-155565 - Fixed an issue where Laser scanning performance was affected with blue and purple points when you re-executed a measurement routine.
•PCD-160256 - Fixed an issue where PC-DMIS didn't display the current alignment in the Report window when you created the SNAPSHOTcommand.
•PCD-163049 - Fixed an issue where the T-probe button was not able to close the Probe Measurement Failedmessage box when you tried to take points.
•PCD-164604 - Fixed a software crash that occurred when you clicked Cancelin the Snapshot dialog box.
•PCD-169301 - Fixed an issue where the labels were lost when you double-clicked on the image in the Report window to edit the Analysis View command.
•PCD-171499 - Fixed a software crash that occurred when you used a Portable online license and opened the Settings Editor application in offline mode.
•PCD-175235 - Fixed an issue where relative measure doesn't work when you selected multiple features from the Graphic Display window.
•PCD-177971 - Fixed an issue where PC-DMIS showed incorrect point positions in the CAD report when the points were used in the loop instructions.
•PCD-180502 - Fixed an issue where you were not able to select the text labels when you selected the Back face cullingcheck box on the Lightingtab of the CAD and Graphic Setupdialog box.
•PCD-185349 - Fixed an issue where the CALIPERcommand was not created properly when you saved a measurement routine to previous versions.
•PCD-186676 - Fixed an issue where the report label changed its position in a custom report when you closed and reopened a measurement routine.
•PCD-187251 - Fixed an issue where a measurement routine was not created or opened when you used a portable SCANMESH license with the Aicon -Offline interface.
•PCD-187655 - Fixed an issue where PC-DMIS didn't display the Pointcloud select area when you edited the Selectcommand from the Pointcloud Operator dialog box.
•PCD-187890 - Fixed an issue where the Colormap Gradient Scale was not shown in the Graphic Display window when you loaded a different scale profile that wasn't the default one from the Profiles Manager dialog box.
•PCD-189889 - Fixed an issue where the Control string and unit fields were missed when Q-DAS Configurator generated the statistics.xml file for the UAME axis of the Size ASME command.
•PCD-191391 - Fixed an issue where PC-DMIS automatically unmarked the Symmetrical check box when you changed the feature type in the Extended Sheet Metal Featuresdialog box.
•PCD-191402 - Fixed a collision issue with laser probes on double arm machines with FDC controller when you executed a specific measurement routine.
•PCD-192421 - Fixed a software crash that occurred when the On Errorcommand failed to set a variable.
•PCD-193410 - Fixed a collision issue that occurred when an incorrect wrist position failed to recover a probe change from Contact to Laser.
•PCD-194926 - Fixed an issue with the I++ DME client where indexing head support was incorrect due to a mistake with how angles were treated if they were not reported from the I++ server.
