Do you mean the feature control frame, if you switch to Xact measure you just click true position and the modifier is in one of the drop downs. if you go to insert/dimension/ and at the bottom uncheck "use legacy dimensions" then Xact measure will automatically start the next time you click true position
You need to create a WIDTH feature to do this with exact or.... Create a generic circle, measure the thickness, assign that value to a variable and then use that variable as the circle size, then dimension the postion with MMC.
when we are checking true position of a part and the datums the position is called out to have MMC as well as the feature does PCDMIS acount for the datums...
Good Morning! I am still very new to PC-DMIS and I am having trouble with the Xact measurement of a true position callout for a feature. The callout for...
What's the best way to dimension true position on a width dimension? Image attached shows critical dimension #2 measures a width, and control frame references...
