2019 r2 sp7
  • 2019 r2 sp7
    ftp://ftp.wilcoxassoc.com/PC-DMIS-Ve...19_R2/SP7/x64/
    Release Notes - 2019 R2 SP7
    PCD-123716 - Fixed an issue where the IMAGECAPTUREcommand added a blank feature label when you had generated the report.
    PCD-145735 - Fixed an issue where the Analysis View was different when you viewed it in the Custom Report and Report windows.
    PCD-147397 - Fixed an issue where the vectors and sizes were incorrect when you used the Create Multiple Featurescheck box in the Auto Featuredialog box for Flush and Gap.
    PCD-158031. Fixed an issue where PC-DMIS displayed a message about the failure to load the HSI.DLL library when you opened PC-DMIS.
    PCD-163049 - Fixed an issue where the T-probe button was not able to close the Probe Measurement Failed message box when you tried to take points.
    PCD-164073 - Fixed an issue where the offline Help didn't work even when the offline help was installed and the Use Offline Help option was selected.
    PCD-164604 - Fixed a software crash that occurred when you clicked Cancelin the Snapshot dialog box.
    PCD-169301 - Fixed an issue where the labels were lost when you double-clicked on the image in the Report window to edit the Analysis View command.
    PCD-170663 - Fixed a hardware crash that occurred when an invalid tip was created for a probe.
    PCD-171041 - Fixed an issue where a laser pointer was not activated when you had done the machine configuration.
    PCD-175235 - Fixed an issue where relative measure doesn't work when you selected multiple features from the Graphic Display window.
    PCD-176498 - Fixed an issue where the pointcloud exclusion plane was connected to an incorrect plane when you executed a measurement routine.
    PCD-177160 - Fixed an issue where PC-DMIS wouldn't automatically switch the Edit window to Summary Mode when you edited a custom report.
    PCD-177755 - Fixed an issue where PC-DMIS showed incorrect symbols for deviations in a custom report when you used positive reporting for all axes.
    PCD-177971 - Fixed an issue where PC-DMIS showed incorrect point positions in the CAD report when the points were used in the loop instructions.
    PCD-185194 - Fixed an issue where the colormap annotations were evaluated at 0,0,0 position when you executed a measurement routine.
    PCD-186676 - Fixed an issue where the report label changed its position in a custom report when you closed and reopened a measurement routine.
    PCD-187890 - Fixed an issue where the Colormap Gradient Scale was not shown in the Graphic Display window when you loaded a different scale profile that wasn't the default one from the Profiles Manager dialog box.
    PCD-188449 - Fixed an issue where Q-DAS Configurator wouldn't report the maximum and minimum values for legacy profile of surface of a plane (Form Only).
    PCD-188578 - Fixed an issue where the diameter of the circle was calculated incorrectly when you select MIN_SEP (Best Fit type) in the Auto Featuresdialog box.
    PCD-188888 - Fixed an issue where the Thickness Colormapscale values were incorrect in the Mesh Operator dialog box when you have not marked the Compare to CADcheck box.
    PCD-189225 - Fixed an issue where PC-DMIS didn't create multiple Mesh Thickness colormaps when you executed a measurement routine.
    PCD-189732 - Fixed an issue where the CAD window displayed the elements and their Ids when you generated the legacy report.
    PCD-190622 - Fixed a software crash that occurred when you typed a non-existing Mesh ID for the MESH/OPERcommand in the Edit window.
    PCD-191049 - Fixed an issue where PC-DMIS didn't import the variables with fixed text correctly when you imported a DMIS file.
    PCD-191391 - Fixed an issue where PC-DMIS automatically unmarked the Symmetrical check box when you changed the feature type in the Extended Sheet Metal Features dialog box.
    PCD-191402 - Fixed a collision issue with laser probes on double arm machines with FDC controller when you executed a specific measurement routine.
    PCD-191484 - Fixed an issue where the Colormaps list box was disabled when the measurement routine doesn't contain a pointcloud.
    PCD-192421 - Fixed a software crash that occurred when the On Errorcommand failed to set a variable.
    PCD-192474 - Fixed an issue where the laser auto features were not automatically executed when data was received from a TCP/IP transfer, such as the AICON OptoCat software.
    PCD-193410 - Fixed a collision issue that occurred when an incorrect wrist position failed to recover a probe change from Contact to Laser.
    PCD-193699 - Fixed an issue where the Thickness Colormap gradient scale value showed a negative percentage at the lowest level when you have not marked the Compare to CADcheck box.
    PCD-194190 - Fixed an issue where PC-DMIS showed a mathematical calibration error when you calibrated a dual-arm machine with laser probes, on Arm2 after you completed the calibration on Arm1.
    PCD-194926 - Fixed an issue with the I++ DME client where indexing head support was incorrect due to a mistake with how angles were treated if they were not reported from the I++ server
    Interesting...
    I always prefer constructing features from least squares autofeatures...
