Working OFFLINE from HOME.
I need to find an intersection of an internal cylinder and an internal sphere. Need to find the height at which the cylinder contacts the sphere. Tried to construct a circle from the intersection of the cylinder and sphere but PC DMIS doesn't support that. Decided my best option was to create a generic point using an intersection formula I googled. Square root of (sphere_radius squared - cylinder radius squared) Tried turning that into an assignment as follows:
DIM D3= LOCATION OF SPHERE SPH1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL X 0.000 0.050 0.050 0.000 0.000 0.000 ----#---- Y 0.000 0.050 0.050 0.000 0.000 0.000 ----#---- Z 0.000 0.050 0.050 0.000 0.000 0.000 ----#---- D 5.207 0.050 0.050 5.207 0.000 0.000 ----#---- R 2.603 0.025 0.025 2.603 0.000 0.000 ----#---- END OF DIMENSION D3 DIM D4= LOCATION OF CYLINDER CYL1 UNITS=MM ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH HALF ANGLE=NO AX NOMINAL +TOL -TOL MEAS DEV OUTTOL X 0.000 0.050 0.050 0.000 0.000 0.000 ----#---- Y 0.000 0.050 0.050 0.000 0.000 0.000 ----#---- Z -4.830 0.050 0.050 -4.830 0.000 0.000 ----#---- D 2.381 0.050 0.050 2.381 0.000 0.000 ----#---- R 1.190 0.025 0.025 1.191 0.000 0.000 ----#---- END OF DIMENSION D4 ASSIGN/SPH_RAD_SQD=D3.R.MEAS*D3.R.MEAS ASSIGN/CYL_RAD_SQD=D4.R.MEAS*D4.R.MEAS ASSIGN/V1=SQR(SPH_RAD_SQD-CYL_RAD_SQD) F1 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<0,0,0>,$ MEAS/XYZ,<0,0,V1>,$ NOM/IJK,<0,0,1>,$ MEAS/IJK,<0,0,1>
