I an looking for a way to automatically export an XYZ point cloud after each part run and to annotate the exported file with a batch number, date & time etc. Any help is much appreciated. Working in 2012.TIA
Automatic Export of XYZ Pointcloud
After creating your point cloud
Insert...Point Cloud...Operator... Select Export from the dropdown, fill out the rest, then parameterize that which needs parameterization.
Code:SCN1 =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=22,SHOW HITS=NO,SHOWALLPARAMS=NO MEAS/SCAN BASICSCAN/LINE,NUMBER OF HITS=22,SHOW HITS=NO,SHOWALLPARAMS=NO ENDSCAN ENDMEAS/ COP1 =COP/DATA,TOTAL SIZE=22,REDUCED SIZE=22, FINDNOMS=NO,REF=SCN1,, ASSIGN/V1="C:\\DADDYSSECRETFOLDER\\LIVESTOCK\\" + SAMPLEID + ".txt" COPEXPORT1 =COP/OPER,EXPORT,FORMAT=XYZ,FILENAME=V1, SIZE=22,REF=COP1,,
- Likes 1
by JEFMANHi all,
I wrote "problem" in the title, but I'm wondering if "bug" could be used...
I usually export hits of scans to...-
10-30-2020, 05:52 AM -
How do I export a point cloud (Using CAD) to SolidWorks so that the point I take are visible? Everything I've tried just shows up as a triangle??
12-02-2015, 02:33 PM -
by eacostaHow can I made that a certain program export to vdaf automatically?
using v3.7mr3-
12-12-2007, 09:02 AM -
by Ken8282Can you export data you get from a linear open scan as a DXF file? If so how would it be done?
10-16-2012, 11:13 AM -
by AmdgkHi,
Can anyone tell me if you can write into the program code to automatically export measured results into a pointcloud (.iges format)...-
09-01-2015, 11:31 AM -
